Maximum Truck Height towing Bigfoot 5th - Fiberglass RV
Old 07-27-2014, 01:26 PM   #1
Trailer: In the Market
Nevada
Hello all y'all:
We are in the market for a small fifth wheel. I have a Dodge 1500 4x4 with a pretty impressive (stock) height above the ground. It's got 20" wheels and tires. I'm aware that one can raise the hitch height in the truck bed but I want the trailer to tow level. I also don't want the trailer to hit the truck bed sides you know?
Who knows the height off the ground of the lowest portion of the front end of those '80s model Bigfoot 5th wheels.
Thanks for the help
Dan
skyboltone is offline   Reply With Quote
Old 07-28-2014, 08:05 AM   #2
Trailer: Scamp 19
I have a Scamp 5er, towed with a 2006 Chevy V-6, and a raised axle with 3" lift. Right now I have about 10" of clearance between the trailer and the truck bed side. I have seen 5th wheels with less clearance but find that at times my trailer gets very close to the bed rail. Since I'm in the market for a new truck, this is something that I have to consider. The best way is to measure from the ground to your bed rails heigth, then also measure a trailer with it is sitting level. I have looked at many trucks and most of the newer ones have very high bed rails. Good luck
captsteve2002 is offline   Reply With Quote
Old 07-28-2014, 09:31 PM   #3
Trailer: 1991 Bigfoot 17 ft
We have a 1989 BigFoot Fifth wheel. We ended up welding a subframe to raise the trailer up 6" and got a slider hitch. We went to Standens in Calgary. Worth every penny because now we don't worry at all. I can send a photo if you would like to see it. We tow with a 2007 Ford Lariat.
mitch is offline   Reply With Quote
bigfoot
Maximum Gear Load in 2012 Scamp 13? CampyTime Towing, Hitching, Axles and Running Gear 11 03-30-2014 06:42 PM
How-to Video: Maximum Use of Minimal Space Francesca Knowles General Chat 8 02-06-2014 09:10 AM
Bigfoot 5th wheel truck box rail height? Cam A Towing, Hitching, Axles and Running Gear 4 08-25-2008 09:20 PM
Scamp 5th wheel truck bed and rail height Rhys H Towing, Hitching, Axles and Running Gear 4 07-18-2008 10:55 AM
Scamp 5th wheel truck bed and rail height Rhys H Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
