89 lil bigfoot reno. Recommend glue? - Fiberglass RV
Old 06-04-2018, 07:13 AM   #1
Trailer: Lil Bigfoot 13.5
Saskatchewan
what is the best glue to use to reinstall wooden support "ribs" that the cabinets are screwed to (the ribs i speak of would be glued to the shell)? Any tips? This is not something I plan to do twice.
I was thinking of just using wood carpenter glue, but not sure due to vibration heat cold issues.
stevelilbigfoot is offline   Reply With Quote
Old 06-04-2018, 07:53 AM   #2
Jon in AZ's Avatar
Definitely not wood glue. Do a "site search/google" (bottom of the search menu) on "glue tabs to shell" and you'll get some helpful threads. Here's one to get you started:
http://www.fiberglassrv.com/forums/f...amp-64695.html
Old 06-04-2018, 10:24 AM   #3
Melly's Avatar
Trailer: Lil' Bigfoot
Not sure what the glue is but our 91 lil bigfoot has metal ribs coming down that support our cabinets. If you are replacing anyway, it may save you some cabinet space!
Melly is offline   Reply With Quote
Old 06-04-2018, 10:52 AM   #4
Trailer: Boler13/trillium4500/buro13
Tab in with fg cloth and resin if attaching right to the fg shell
Mikmay is offline   Reply With Quote
Old 06-04-2018, 10:56 AM   #5
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
Yup, I'd tab them back into the shell with fiberglass matt and resin. I can't imagine any other glue that would hold while supporting the weight of any of the interior furniture/cabinets.
bill (not laura)
Old 06-04-2018, 11:53 AM   #6
Trailer: Scamp 13
If it was my trailer I would glue the ribs in place with pl adhesive just to hold them in place and then use fiber glass and resin to make permanent connection to the wall.
https://www.homedepot.com/p/Loctite-...0595/202020473
https://www.homedepot.com/p/compare/...20repair%20kit
Old 06-04-2018, 12:08 PM   #7
Trailer: Bigfoot 13.5 ft 1987
I did the same cabinet repairs to my 87 Lil Bigfoot. The original wood was glued to the fiberglass. I don't know what the original glue was but it eventually failed. I won't be storing anything very heavy up there anymore.
I researched other modern adhesives and settled on PL Premium (Loctite or Lepage). I pre-tested some on scrap wood and fiberglass. It seems very strong and it's lasted 3 years so far and I travel lots of bumpy roads. Time will tell, but I am pleased with the result.
If you want a more flexible adhesive, I have also used E6000 Industrial Adhesive with very good results. They claim it is 2X stronger and 60X more flex than Polyurethane.
Whatever you use, strip off all the old adhesive from fiberglass and wood strips (if you re-use original wood strips).
John DM is offline   Reply With Quote
Old 06-04-2018, 02:24 PM   #8
Trailer: Lil'Bigfoot
If it was me, I would tab in some marine grade plywood and resin both sides of the wood like a boat.
jn3521 is offline   Reply With Quote
bigfoot, eco
Complete lil Bigfoot reno Toykiter Modifications, Alterations and Updates 61 08-09-2022 03:20 PM
What glue is the best to glue the fabric on the sealing. Falicea Problem Solving | Owners Helping Owners 11 10-31-2017 09:22 PM
Anybody recommend a repair shop in Reno, NV brownrecluse Modifications, Alterations and Updates 9 10-25-2012 08:37 PM
Lil bigfoot reno's, wall lining suggestions. Siddallc Modifications, Alterations and Updates 1 06-18-2012 11:08 PM
88' Lil Bigfoot Reno Complete Mike Whitney Modifications, Alterations and Updates 28 04-12-2012 01:26 PM
