For Sale: Sunrader ford F250 - Fiberglass RV
Go Back   Fiberglass RV > Marketplace > NEW Fiberglass RV Classifieds | Buy, Sell, Trade
Old 05-04-2019, 10:32 AM   #1
Trailer: Previously owned 1991 Ford Airstream B190
Sunrader ford F250
4WD Adventure Rig!
Climbers! Overlanders! Vagabonds! Can t afford a 4X4 Sprinter? Here ya go!
Willing to sell Camper Solo for 10k Firm.
Designed and built with the following elements in mind:
Ability to be lived in full time if desired
Truck and camper combination allow for living space and truck to be used together or separate which means you have a fully functional work truck!
4 wheel drive to access all the far out there places
Functional and stylish design features make it feel like a home, not an RV
Can run Biodiesel or WVO
Can get 22 MPG!
Average around 18 20 MPG.
Read on for all the tech specs and nerdy details!
The Truck:
1996 Ford F 250 HD
7.3L Diesel
150,xxx Original Miles
Clean Title
4x4
Automatic Transmission W/OD
Cruise Control
TS 6 Position Chip uninstalled
Warn Manual Locking Hubs
BF Goodrich KO/2 AT M S Ice Tires like new w/ warranty
Power Locks
Power Windows
Dual Fuel Tanks
Ice Cold AC
Strong Heater
Running Boards
Extended Cabin seats six
Long Bed
10,000 lb Class IV Tow Hitch Receiver
Triple Ball Hitch 1 7/8 , 2 , 2 5/16
Locking Hitch Pin
Tekonsha Voyager Brake Controller
200 watt LED light bar
Carhartt Seat Covers On All Seats upholstery is perfect underneath
Upgraded JVC Deck with Bluetooth, Handsfree, and CD player
Upgraded JVC Speakers; Front and Rear W/ Integrated Tweeters
Snow Chains
Recovery / Tow Strap
Jumper Cables
Purchased the truck Jan 2017
Upgraded 6637 Air Filter
New Vacuum Pump 2017
New Alternator 2017
New Water Pump 2017
Front Brakes / Rotors 2018
The Camper:
Built in the spring of 2018
Rare Sunrader Fiberglass Cabover Camper Shell W/ Raisable Rear Door
Entire Fiberglass Shell Sanded / Patched / Painted
Wood Sub Frame
Walls / Roof / Floor / Under Bed Insulated W/ Reflectix Bubble Insulation R4 Then 2 Reflective Foam Core Board R10 Then Siding / Floorboards / Plywood
Marine Grade Plywood Lower Bucket
Custom Made Blackout / Insulated Curtains
2 48 x 20 Sliding Glass Windows W/ Screens
Maple Hardwood Floors
Aeromatic Western Cedar Siding
Birch Butcher Block Countertops
Maple Kitchen Cabinets W/ Locking Hardware
Stainless Steel Sink / Tap W/ Automatic Pump
7 Stage Reverse Osmosis Filter W/ Separate Tap
3 Birch Butcher Block Backsplash
Camp Chef Aluminum Dual Burner 40,000 BTU Mountaineer Stove
High Efficiency Whynter 62 Quart Dual Zone Fridge / Freezer
Maxxair Fan 7500k 10 Speed, Thermostatic Controlled, Intake / Exhaust, Powered Opening
48 Plexiglass Skylight Around Fan
Camco Olympian Wave 3 Catalytic Safety Heater 3,000 BTU
Stowable Birch Butcher Block Table
5 Gallon Propane Tank
30 Gallon Fresh Water Tank W/ Fill On Side Of Camper
5 Gallon Grey Water Tank W/ Drain Tube
5 Memory Foam Mattress
Power
3 x 100w Renology Solar Panels 300 watts total
2000w Continuous / 4000w Peak Pure Sine Wave Inverter
300 AH Liquid Gel Deep Cycle Batteries
30A Solar Charge Controller
2 x 110v GFI Protected Outlets Hard Wired To Inverter
6 Recessed LED lights W/ Dimmer
12 Terminal Fuse Panel
HappiJac Frame Mount Tie Down System W/ Stabilizer Bar
HappiJac Turnbuckles
2 Slide Under Jacks To Remove Camper not pictured
The entire camper is self contained and is fully operational without the truck. Willing to sell camper separately but will not sell just the truck.
Dimensions
Floor to Ceiling 70.5
Bed 67 x 60 Short Queen
Total height: 10 Tall
Tags: sunrader, sprinter, RV, class b, cabover, express, savannah, promaster, nv2500, overland, offroad, custom, vanlife, van, conversion, stealth, camping
View this ad at Fiberglass Classifieds - Sunrader ford F250
tylerm1123 is offline   Reply With Quote
Old 05-05-2019, 10:54 AM   #2
RJnNC's Avatar
Trailer: 1982 Burro 13'
Are there any other's unable to view classified ads? This is the message I receive:
"This site can’t provide a secure connection
www.fiberglassclassifieds.com uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH"
RJnNC is offline   Reply With Quote
Old 05-05-2019, 03:05 PM   #3
Jon in AZ's Avatar
No such error here. You might contact the site administrator Janet H. directly vis PM. She is very knowledgeable about the technical side of the forum.
MI: Toyota Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 37 01-15-2016 10:06 AM
*~*~RARE For Sale: Toyota / Sunrader 4X4 22RE SR-5 Opt. checkursix Classified Archives 4 04-16-2015 07:03 PM
MI: Sunrader Mini Motorhome Thomas G. Referrals: Molded Fiberglass Trailers 9 04-03-2013 08:41 PM
MI: Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 4 11-10-2012 04:01 PM
