02-21-2014, 03:27 PM
Trailer: Boler
100 watt flex able solar panels
What say you with the bendable or flexible solar panels?
I am looking at some 100 watt panels but want the best of both worlds. I want to install on the roof but also be able to move them around when needed. Yes I would have to come up with a way to mount them on the roof but still be able to take the down and move them?
The roof mount panels are great but I would run into times when they are not so great and so on with the folded moveable panels. They both have draw backs.
How about some flexible panels that can be mounted on the roof but yet moved to the sunlight when needed. Anyone else on the same page as me?
02-21-2014, 03:48 PM
I think the big advantage to flexible solar pannels is the ability to mount them flush on a curved surface. I would use VHB tape, around the perimeter. This would not be removable. I am inclined to think that the flex cells, if they are polly, or mono-crystalline, would be prone to breakage if you handled them too much.
02-21-2014, 04:13 PM
Trailer: Boler
Dave, what if the panels were moveable and could be flush on a curved surface? What if they could be walked on without breaking. Say 3 lbs for a 100 watt panel!
What if we could put them on the roof but while in the shade move them to a sunny location. Yes, I have been doing the "research" for what I want. I think I may have found a flexible 100 watt panel that can be moved as need that weights only 3 lbs. Would you rather have this over a reg solar panel or a fold able panel at a lower cost? I would love your input!
02-21-2014, 04:51 PM
While not as efficient as crystalline panels, I suspect the amorphous panels are the future. There is research at many institutions into thin film deposition on many substrates including paper. I have even read about organic solar panel paint. I have an old amorphous panel that I've used for 10 years. I'm starting to look for a replacement. The Unisolar roll up panels look attractive. You could use Velcro to attach to the roof or put where you want. Pull it off and roll it up when traveling. For now I'm just looking to see what comes. Raz
02-21-2014, 04:53 PM
Trailer: Escape 17 ft Plan B
I want a panel that takes the place of the awning fabric!
02-21-2014, 05:00 PM
Trailer: Boler
What if you could just throw the solar panel on top of your awning? At 3 lbs, you could!
02-21-2014, 05:38 PM
If I'm going to be away from the trailer and the weather looks threatening ( wind ) I furl the awning. So, if it was solar, I'd not be charging.
02-21-2014, 06:32 PM
Trailer: 93 Burro 17 ft
Oklahoma
If you want to charge from the panel while moving down the highway, fastening a panel to the roof is the way to go. If you don't want to do that, simply get the panel out when you set up camp and put it wherever you wish: on the trailer roof, on the ground, on your tug, whatever.
There is also nothing wrong with having more than one panel, with one fixed on the roof and another unmounted. You just need an appropriate controller that's capable of handling one or both panels.
Trying to mount one on the roof in a way that it can be dismounted and remounted at will sounds needlessly complex and impractical to me.
02-21-2014, 08:11 PM
I'd keep the one on my roof, and just unroll the awning version when I was at the trailer & the wind was down. The thing I like about it is the ease of storage, and the fact that is is serving dual purpose - I try to do that with as much as possible living in a small trailer!
My 95 watt panel tries to keep up, but I have to watch my usage. With the area of the Escape's awning, I'd have far more than I need...
02-21-2014, 08:49 PM
Name: Norm and Ginny
Trailer: Scamp 16
We have 80 watts of flexible mono solar panels permanently mounted to the roof with VHB tape. They have been on for about 3 years and 60,000 miles thru all kinds of weather. There are two separate 40 watt panels. They each weigh 2.2 lbs.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
02-22-2014, 12:12 AM
We had a 100 watt panel mounted on the front of our Scamp that could be angled from a down position, up to a 30 degree over a horizontal position. We rarely ever raised it, and after a while, never even oriented the Scamp facing directly south, because it kept our group 27 battery charged in just a few hours of light. I really doubt that you would ever need to move 100 watts around to keep up with your needs either. One could always plug your 7 pin connecter to the tow vehicle to combine the vehicle batteries for extra stored power if needed until the sun comes back up.
Dave & Paula
02-22-2014, 06:25 AM
That's a problem I haven't figured out. I want a panel that can be easily stored in the trailer when not in use i.e. rolled up. But at such light weight it has to be mounted to something or it will blow away. Having to bring something to mount it on kind of defeats the storage benefit. I suppose you can put it on the ground with rocks holding it down, but...... Any thoughts?
These Unisolar panels have been around for a while. I believe they were originally intended to mount to a roof. Unisolar had financial trouble but when you do a search, you end up at BASF.
I'm hoping for an upgraded version. Perhaps at a price similar to crystalline panels. I have never seen one of these panels in person, so I have no idea how well they would hold up to rolling and unrolling. Being designed for permanent roof mount they may be limited as to how much flexing they will take. Raz
02-22-2014, 07:21 AM
Trailer: Scamp 16
For us the problem with UniSolar rollup panels is that they do not fit on the roof of a Scamp. Secondarily they are larger than an equivalent monfilament panel because they are less efficient.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
02-22-2014, 07:37 AM
The 68 watt is 15.5" x112" which would be close on my Trillium roof.
02-22-2014, 08:20 AM
Trailer: Scamp 16
I seriously looked at the Unipolar panel. One problem is finding a straight run without vent openings and the like. The reality is that it's surface area is about twice my 80 watt panel(s).
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
02-22-2014, 08:57 AM
Trailer: Boler
Monocrystalline Panel
41" x 21.25" x .19"
Maximum Power at STC(Pmax)100WOptimum Operating Voltage (Vmp)17.8VOptimum Operating Current (Imp)5.62AOpen-Circuit Voltage (Voc)21.6VShort-Circuit Current (Isc)5.97ADimension1050 X 540 X 5mmWeight3lbs
02-22-2014, 09:06 AM
Trailer: Boler
The size is right. The watts is 100 each and only 3 lbs.
Now I would have to make someway to have this installed on the roof but be able to remove it quick and without a ladder.
Maybe something like a window frame where you could use a pole to unlok it (like the old school house windows) and slide it over the side.
If not I think 2 of these panels just might work on the roof. And as time goes on I might be able to make a system that would let me remove one without a ladder.
02-22-2014, 11:37 AM
Two ideas.
Industrial grade Velcro available at many hardware stores. It lasts about two seasons. At that weight you won't need much.
Rare earth magnets. Peter H. glued rare earth magnets inside his trailer to hold an access hatch door open outside the trailer. Quite clever. Raz
http://www.fiberglassrv.com/forums/f...tch-34476.html
02-22-2014, 12:33 PM
Trailer: Boler
They have eye hooks on them. Wonder if you can use them with something like a bungee cord or something.
I just got back from the storage unit to check on the roof of the Boler and I will now have to put on my Protoype thinking cap!
02-22-2014, 07:44 PM
Trailer: 1980 13 ft. burro
Wouldn't something like that attached down with bungees act a little like a sail?
Certainly a fun engineering problem.
What about a system that would let you slide and lock the panels into a frame? Thinking something analogous to the rails a sliding door or a window move around in, but with one side that can open and close.
