Originally Posted by yogavnture
but none of the failures you speak of will lead to danger? i need to wake up .i looked on supply house .com they have a sku number 710-205 its a low profile combo gas valve. 1/2 inch by 1/2inch cost is 108.99 us dollars i wonder if that would fit mine. looks similar. heck david we are almost to the point of reproducing these unique heaters that we don't want anybody else to know about cause they are safe . reliable and unlike buddy heaters don't fume out. i still wonder why u want to see numbers on my gas valve i will try for you. its at my rv guy right now who is fabricating extension for the vent the tiontivv iualtn tto
Ummm.... That last sentence was kind of garbled. Were you going through a tunnel?
The only reason I want to know the model number of your gas valve is curiosity. Assuming it is not a model number I have come accross, it adds to the list of valves that I can use. So don’t go to heroic efforts to find out, though a mirror would probably make it easier.
Be careful of what gas valve you choose. There are several other, less expensive, Robertshaw gas valves that look exactly like the 710-201, but lack the thermocouple gas shut off feature, or something else. I have looked for a less expensive alternative, but found none. Either way the plumbing is different and would require someone with tube bending experience. That might be the most expensive part.
Probably the least expensive alternative is to find another
furnace that uses the same valve. No guarantee that it works though. This is how I have an inventory of about 5 spare valves, one that is in pieces, and missing the large rubber diaphragm.
