Airstream 16' FG launch - Page 3 - Fiberglass RV
Old 01-02-2018, 08:12 PM   #41
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Looking at the two pictures makes me like my Snoozy even more. Airstream has the blacked out windshield as a unofficial trademark but I donít see the utility. I can see why AS dumped the frameless design. That would be asking for trouble.
Old 01-02-2018, 08:18 PM   #42
rbryan's Avatar
Arkansas
I do. How about a beautiful view?
How so? Robert's original design provided more than enough structural strength to go without a conventional frame. It's likely they went with a frame not to avoid trouble, but due to production cost or manufacturing complexity in duplicating Robert's shell exactly. I'd be interested in his take on the subject.
Old 01-02-2018, 08:30 PM   #43
ZachO's Avatar
Trailer: Sasquatch
Montana
Well I'd agree that the only similarity is the rear door. Otherwise, completely different designs that'll appeal to completely different people.
I really like the look of the Airstream, but seeing as I'll never buy one, I guess it doesn't really matter
Old 01-02-2018, 10:13 PM   #44
Trailer: Sprinter 'til I buy
Denver, CO
Not to argue, I also see them similar, not same. I'll also grant that there are only so many ways to arrange a bed, bath, and kitchen.
Similarities:
The rear doors
Above average ceiling height.
Aerodynamic front ends, that 'break' the typical egg shape.
Wide center aisles
Counter along a side wall.
Large smoked glass windows
Side baths.
Tom 72 is offline   Reply With Quote
Old 01-02-2018, 11:20 PM   #45
Trailer: 2009 Escape 17B
The slab rear end on the Snoozy cancels any aerodynamic advantage at the front.
Old 01-03-2018, 08:24 AM   #46
ZachO's Avatar
Trailer: Sasquatch
Montana
No let's argue!
I think it was just the implication that Airstream (or I guess Robert) basically copied the Lil Snoozy that set off the last few posts. Are the similar? Yes. About as similar as all fiberglass trailers are to each other, in that they're small, and tend to have a top and bottom section and belly band.
Beyond that, to my eyes the design is very different. The Snoozy is a wedge shape. The Airstream closer in shape almost to an Escape than a Scamp/Casita/Boler, but closer to the Boler shape than the Snoozy shape. Reminds me a bit of a bullet train..
Old 01-03-2018, 08:38 AM   #47
ZachO's Avatar
Trailer: Sasquatch
Montana
Old 01-03-2018, 11:53 AM   #48
I hope they bring the trailer out to the Quartzsite RV show.
Old 01-03-2018, 11:57 AM   #49
Trailer: Escape 15A
You're right... a lot of people don't seem to realize that aerodynamics on the back end are just as important as the front.
Steve Carlson is offline   Reply With Quote
Old 01-03-2018, 12:15 PM   #50
charlsara's Avatar
It is true that the rear shape of the LIL Snoozy is to square for good aerodynamics. It looks like the Nest is about the same.
Old 01-03-2018, 01:44 PM   #51
rbryan's Avatar
Arkansas
In order to make a trailer more aerodynamic, something's gotta give. It could be interior space, height, width or length, or maybe storage space. While the Snoozy has the most aerodynamic front, that means the severe slope in the bed area. The Nest is more aerodynamic in front than most trailers, but the rear entry does pose an aerodynamics issue. I would say it's not as severe as the completely flat back of the Snoozy however, since it has quite a bit more rounding just before the back area, and there is also a recess all the way around that helps create a spoiler effect.
Old 01-03-2018, 02:28 PM   #52
ZachO's Avatar
Trailer: Sasquatch
Montana
So is this a 3-piece? Top, bottom and back?
Old 01-03-2018, 02:30 PM   #53
Trailer: Escape 15A
Agreed... that little taper at the back end will make it the exit aerodynamics a lot better than a right-angle back edge.
Old 01-03-2018, 03:08 PM   #54
charlsara's Avatar
The sloped area in the front of the Snoozy is completely usable, that's where the bed is. It is a little more square at the back but the corners and sides are rounded off to. The Snoozy is also 2 feet longer. I don't know what the cabin length is on the Nest but the Snoozy's cabin is 14'. I noticed the Nest has a raised section on the rear roof. I wonder if the is the "stand up" area. In the Snoozy the roof stays high until right at the queen bed.
Old 01-03-2018, 03:13 PM   #55
charlsara's Avatar
As far the spoiler effect. That remain to be seen. I doubt if there is enough wrap around to make much of a difference.
Old 01-03-2018, 03:14 PM   #56
rbryan's Avatar
Arkansas
Yes of course the bed is useable, but you do lose overhead space as well as alot of underbed storage. As I said, there are always tradeoffs.
Old 01-03-2018, 08:59 PM   #57
charlsara's Avatar
True , but the Snoozy being two feet longer probably has more under bed storage. Like all of you I am eager to see what AS has done to the nest.
Old 01-04-2018, 08:32 AM   #58
Carl Pa's Avatar
By the time you get that on the road, buying a few more options, paying sales tax. You are up to almost 50K. Will there be people willing to spend that much money to stay in something smaller then your bath at home. Who knows ? Carl
Carl Pa is offline   Reply With Quote
Old 01-04-2018, 08:42 AM   #59
ZachO's Avatar
Trailer: Sasquatch
Montana
Easy answer: Yes.
Old 01-04-2018, 10:31 AM   #60
Hidalga's Avatar
Trailer: Modified 13' Scamp
Full-Timer
Originally Posted by vintageracer View Post
Pics of what yer gittin from from 2 "Nest's" as shown by Airstream front and center at the RVIA National Dealer's show in Louisville November 2017!
Just saw this thread and quickly scanned through posts. If it hasn't been clarified already, the bottom 3 images are not from Nest. Two different floor plans will be offered. These two units will most likely not be displayed at consumer shows before launching, because they were prototypes and there may be minor changes before the April launch. Robert and Airstream were still processing industry feedback at the RVIA show.
RV Compass: Unconventional Rallies for Independent RVers
Publisher of The Roost - the monthly e-newsletter that reports mass flockings of Egg trailer enthusiasts
Hidalga is offline   Reply With Quote
Soon to launch into fulltime. Gennaver Problem Solving | Owners Helping Owners 4 01-08-2016 01:01 PM
15 dsys to launch. Infogypsy Problem Solving | Owners Helping Owners 2 09-10-2013 03:54 PM
Darn Clouds! Hid Shuttle Launch melissab General Chat 7 02-25-2011 10:12 PM
The $49,000 15' Airstream "Design Within Reach" Patrick M. General Chat 12 06-06-2007 06:00 PM
New Airstream Chester Taje General Chat 15 08-10-2006 08:27 AM
