For a newbee trying to figure this
solar power stuff... I like to explain in simple terms.
Who does it work ?
Almost the same as your car does.
1 car has a battery
2 the battery stores electricty
3 when u start your car the power taken from the battery is replaced by the alternator and the alternator charges it till its full again. The alternator is a battery charger.
RV
solar system
when u use power in your rv if comes from the battery like your car. But most rv's don't have engines to turn a alternator to build the power back up in the battery so plugging in the RV to shore power is the same as a alternator as it powers a battery charger.
What does a solar system do then ?
A
solar panel is a battery charger but instead of the charger being power by a car or a shore power. The
solar panel is powered by the sun. So its just another battery charger.... but it most cases it has a solar controller between the
solar panel and the rv battery. The controller controls when the solar panel sends power to the rv battery. It controls the rate and level of power to build the battery up again.
So think simple.... a solar panel is a battery charger :-)
