Boondocking - Fiberglass RV
Old 01-15-2022, 02:43 PM   #1
Trailer: 2013 16ft Scamp
Boondocking
Boondocking at Saddle Mountain in AZ. Test driving my new Battleborn Lithium ion 100ah battery. Worked like a charm. I am so done with lead acid batteries that die every few years.
Campingbliss is offline   Reply With Quote
Old 01-15-2022, 07:19 PM   #2
Shocksll's Avatar
NC
Nice, this has been my first winter with my two heated 100Ah Battleborn batteries. Since the heating is done internal to the battery, my BMV is unable to detect this usage. Today i noticed that the battery heater must be getting turned on because the BMV was showing 100% but my solar was still dumping 7A of charge into them.
4D108CB5-7C7D-4214-8092-7A29822BA371.jpg   8EE2817A-65BB-4D32-9994-200EB886C00A.jpg
Shocksll is offline   Reply With Quote
Old 01-16-2022, 11:05 AM   #3
Trailer: Scamp 1995 19'
Gorgeous
What a beautiful picture.
I grew up in Yuma. The desert is a very cool place in a very different way.
JWColby EAAT
Exalted Arbiter of Anal Tripe
jwcolby123 is offline   Reply With Quote
Old 01-16-2022, 01:13 PM   #4
Raspy's Avatar
Trailer: Xplore X22
Smith Valley, Nevada
That is an interesting problem. The lithium battery monitors typically count amps in and amps out to determine the percentage of charge, while the charger looks for a voltage rise to determine full charge. So if the monitor doesn't see the internal heating load, it has no way of factoring that into the percentage of charge.
How will you resolve this? Maybe you'll have to wait until the battery is fully charged, based on the charge current going to zero, and then reset the monitor to 100%. But in cold weather you'll never know exactly what the state of charge is.
I don't like the idea of the battery using its charge to heat itself. What a waste. But with outside batteries, that seems to be required. So, lithium batteries on the trailer tongue, or in exposed pull out trays, like the Oliver has, will have this disadvantage. Installing batteries inside the trailer is the solution for winter camping. As the industry moves more toward lithium, putting the batteries inside will have to be considered and should be looked for when purchasing a trailer.
My X22, for instance, has them centered in the trailer, under the bed. In winter, battery usage is high and the sun is weak, so wasting energy to electrically heat the batteries could be a problem. And a false monitor percentage will hide that problem.
Raspy is online now   Reply With Quote
Old 01-16-2022, 01:31 PM   #5
Shocksll's Avatar
NC
Yep, this is one reason i have mine installed inside my camper. https://youtu.be/5lzwRLJOBI8
When I’m camping i leave my thermostat set to 45 in order to keep the pipes warm and there is less a chance the batteries will need to heat themselves.
Right now it’s winterized and sitting in my driveway and having solar means i don’t need to connect it to shore power but it also means I’m not heating the trailer thus the batteries are having to heat themselves.
I do think the controller is smart enough to continue charging until the bmv stops it. Whenever i use my battery disconnect the bmv gets out of sync but figures it out when it’s charged fully. So I’m not too concerned with the bmv getting out of sync.
boondocking
Ultimate Urban Boondocking JOHN PAUL EVANS General Chat 19 04-05-2012 02:49 PM
Boondocking without suffering Gina D. Modifications, Alterations and Updates 31 11-12-2006 11:53 PM
Boondocking Maine/Vermont/New Hampshire Dick Pack Camping, Campout Reports 10 11-08-2006 07:58 AM
4th Moose River, Boondocking In Northern NY Al V Rallies, Get-togethers, Molded Meets (Archive) 14 10-10-2006 07:44 PM
