converter upgrade - Fiberglass RV
Old 06-22-2021, 05:07 AM   #1
Trailer: 1978 prowler
converter upgrade
hi everyone I have a 1977 prowler travel trailer, with a powertron converter. I am looking to upgrade it to a new one but not sure what to get to replace it .
Thanks in advance for anyone's help.
JIM
james ivan is offline   Reply With Quote
Old 06-22-2021, 06:58 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
To make this decision, you need to consider:
- are you also replacing the power distribution panel (110 vac breaker panel and 12 vdc fuse panel), dimensions
- your dc amperage is 40 amps; do you want to increase it?
- your ac amperage is not shown; probably should upgrade to 30 amps or 50 amps if not already there; add a 30 or 50 amp shore power inlet connector if not already added; upgrade the wiring between the power distribution panel and the shore power inlet
- what type of battery charger is needed
Progressive Dynamics is a good solid brand and makes a wide range of deck mount converters, power distributions panels and combined units.
Power converter/charger replacement/upgrade Alpenbaker Hi, I am.... 11 05-30-2020 01:13 PM
77 Trillium, Converter Upgrade Options Doug2000 Modifications, Alterations and Updates 1 09-09-2013 12:53 PM
U-Haul Power converter upgrade. Youhauler Modifications, Alterations and Updates 7 07-10-2013 07:59 AM
UHaul Converter and Electrical Panel Upgrade Thomas G. Modifications, Alterations and Updates 5 02-13-2013 10:31 AM
Need advise on new converter upgrade FredericL Problem Solving | Owners Helping Owners 9 05-14-2009 08:52 AM
