How much HANDY ??? - Fiberglass RV
Click Here to Login
Old 04-30-2015, 09:11 AM   #1
Trailer: Escape Trailer - SOLD
How much HANDY ???
Hi, a Newbie here,
I am starting to look around for a used fiberglass RV to start my retirement travels.
Among other things my incapability to get things done/fix handy things around the house is putting a cramp in my excitement to RV and is the reason for this question to other forum members.
I & my wife do not know whether we will take to RVing in real life as I have been living the pleasure vicariously on the various RV forums/websites/in a digital format so far. That was the main reason for getting a used RV, as the worse scenario will not hurt as much
HOW HANDY ARE YOU around the RV or how Handy does one NEED to RV.
Or is it a good idea to just go ahead & buy a new trailer, hoping to at least avoid these challenges in part.
- Or did you learn(You tube/google/RV camps) the skills as you traveled & get only major things fixed at the RV places.
Thanks for any output from the members.
Regards
disneydoc is offline   Reply With Quote
Old 04-30-2015, 09:43 AM   #2
Trailer: Class A Motorhome
Sounds like you are asking the right questions.....
It's all about condition, condition and condition, Many FGRV's are now over 40 years old and are still going down the road with minimal repairs done/needed. On the other hand, a few that I have seen that are less than 5 years old, are in need of major repairs. BUT, if you get a good one first, and take care of it, maintenance and repair expenses will be minimal.
As you, basically, want to try a "trial experience" with minimal $$$ risk, may I make the following suggestion.
At the end of the season (September/October) start looking for one that the owner has finished up with and wants to sell. Take a few months for any minor cosmetic adjustments and try some weekend trips etc to see if you like it. If so, all is good, if not, put it back up for sale in April/May and you will usually more than break even and might even make a profit.
BUT: DO NOT buy one that you know needs work that will have to farmed out to the local mechanics/RV shop, that will get expensive fast.
As another alternative, there are companies and a few individuals that rent FGRV's you might try that first as well.
Basically, for those that don't do their own work, (and for many that do) it's almost always cheaper to buy the very best you can afford up front, than to buy something that will need farmed out repairs.
About how to get the needed skill sets?
I see the sources you mentioned as supplements for those already with the basic mechanical/electrical skills needed to work on an RV. Not having those can often get one into trouble as more than a few (Youtubes especially), demonstrate often unwise and unsafe methodology. And what's "Simple" for Joe the RV mechanic/bodyman/electrician etc, can be a daunting challenge for the unskilled.
I've been turning wrenches for over 50 years, was an aircraft technician in the NAVY and taught technical subjects in a community college, so I can't really remember anymore how I actually "learned" ... LOL
Old 04-30-2015, 09:59 AM   #3
David B.'s Avatar
Welcome to the forum Raj. Don't let your fears keep you from living your dreams & experience travel in the real world. I believe that ANY type or brand of RV will need some type of repair or maintenance regularly, as everything is moving and shifting as you travel, and you can learn a lot from others here on this forum and from youtube. All moulded fiberglass towable's will not have seams to leak and start all the problems associated water intrusion. A new unit should in theory give you less problems, and will have a warranty from all the manufacturing companies that make up the trailer (ie: battery, water pump, furnace, refrigerator, etc.), so you shouldn't have to work on it yourself, but if work is needed, you can get educated from the repair facilities that will be doing the work. I believe you should at least learn how to use a screwdriver in conjunction with some type of thread locker, to keep up on all the fasteners that work their way loose as you bounce down the road making memories.
Dave & Paula
Old 04-30-2015, 10:54 AM   #4
Don't know what your getting into: start with your tow rig of choice and read the owners manual and see what the factory recommends for towing. Now you have a guideline.
With out skills this is where I would start.
Read our thread here towing weights in the real world. This will give you a guideline on our choices of fiberglass trailers and what realistically can be towed by your tow vehicle.
Now the choice of trailers If it were me I would look for a 3-4 year old trailer.
Walk in and use your nose if it smells bad or is covered in perfume walk away.
If it stinks and you don't have the skills to fix it its going to take real money to fix it.
Now make the owner prove every thing works properly in the trailer and don't take the excuse we never used it, I don't know. Test it. What ever doesn't work is going to cost you $500 to have someone repair it or even more to replace it since you don't have the skills to repair it.
Especially important is to have water in the water tank and with all the faucets closed turn on the water pump and leave it on. The pump will pressurize the water system and turn off itself. While doing the rest of your inspection you should not hear the pump cycle again since the system is closed. If it does cycle then there is a leak. Could be something simple or something real bad. The more the pump cycles the worse the leak will be. Undetected leaks destroys trailers.
There is a pre-buy checklist on this site.
By choosing to go fiberglass you will pay premium for a used trailer but if you choose to get out and sell you mostly get your money back on a used trailer. A new trailer you will loose money. Really depends on how important a new $4000 mistake is to you. With used paying fair market your mistake could be closer to $1000 or may even make money. Used is worth the leap as long as you don't buy junk.
Buy choosing a 3-4 year old trailer you are less likely to have to deal with major expenses like a 8 to 10 year old trailer.
If you choose to go to the dark side and choose a wood and flat sided trailer any trailer you buy should be inspected by an RV professional not associated with the seller. These trailers have a hundred places that water can leak. Both inside and outside and since they are built with wood, a leak gone unrepaired can be disastrous.
I have been in manufacturing for over 40 years. Started as a machinist and a jack of all trades up to assembling a manufacturing plant and managing operations. Currently out of the metal trade and working in the Composites world. For my personal well being working and restoring cars have been in my life since i was 15.
My first real work started when I was 10 years old where I cleaned and sealed the seams on trailer roofs in the trailer park where my grand Parents lived. I also had the job of cleaning and re-padding swamp coolers and covering them in the fall and opening them up in spring. I had about 12 trailers under me using me for service. A 10 year old on top of an old trailer does no damage compared to a 200 lb man. An old man named Bob trained me and really made a difference whether the family ate or not. Bless him, I never thought to thank him, I did this until my grand mother died and we no longer went to the trailer park. It was a good 5 year gig. I was 15 and then started working in the machine shop. We needed the money I had to work. I don't pay anyone to do anything for me except Smog checks and medical both of these I am not allowed to do. Pretty much self educated, buy the book and dig in. I have allot more money in books than tools and I have allot of tools. Now I turn on the computer and fire up Google. As I age now things take twice as long and seem twice as hard and are associated with twice the pain. Wont be long before I have to start funding the rest of society.
Old 04-30-2015, 12:55 PM   #5
The Minimalist's Avatar
Louisiana
The bad news: Whether you buy new or used, you're going to have to build your skill set. As is said, "Stuff happens.", and according to Murphy, at inopportune moments (read "on the road").
The good news: Most trailer systems are relatively simple, and any skills you don't have you can develop on the trailer, and maybe transfer that knowledge to home maintenance.
The really good news is that you have access to a world of experience and knowledge on this site, and friendly folks willing to share.
So, don't let your inexperience hold you back. Keep to the smaller trailers with the simpler systems and learn as you go. I think you will find lot's of folks here who have done just that.
Spend lot's of time in "Maintenance and Restoration" forums.
Take your time, think it out and plan carefully...........and welcome to FGRV.
Clif
Old 04-30-2015, 01:03 PM   #6
Thank you David, Bob Steve & Cliff, appreciate you taking the time to help.
That was good advice -
1)New or late model 3 to 4 yr old fiberglass trailer
2)Our Lexus 350 has a towing capacity of $3500 from the owner's manual. I will try to pull first by this, if it is not working out then I will upgrade the SUV.
Will start looking for Scamp 16, Casita 16 (17?? because of heavier hitch weight) or an Escape 17 if I could find one.
A new Escape has a lower hitch weight and I think in some ways would be perfect but takes 9 to 12 months for delivery, I do not know if I can be patient that long.
For some reason, I noticed there is not much fiberglass Trailer activity in general in Florida & nor that many for sale.
Thanks again
Old 04-30-2015, 01:53 PM   #7
Advice....
Thanks again
About the only place in on the planet that you will find FGRV activity might be in Southern Calfornia, they just aren't that common, to keep prices half sane, most of the builders don't use dealers and a lot of them change hands between peeps that current owners know who had amassed an existing waiting list.....
Follow your area Craigs lists every day as well as <<<fiberglass-rv-4sale.com>>> and be ready to pounce as soon as you see a listing. Most good ones, at anywhere near decent prices, tend to last hours, and seldom days and you are in an area where demand might be higher than elsewhere.
And be somewhat flexible for your first unit. There just aren't that many out there and that odd color upholstery or even the attitude of the seller, may just be something that you will have to deal with.....lol
Good Luck
Old 04-30-2015, 03:09 PM   #8
David B.'s Avatar
Raj, have you looked under the "Classifieds" section of this page? There are a couple of Parkliners for sale, and of course, the Lil Snoozy factory isn't that far away either.
Dave & Paula
Old 04-30-2015, 05:09 PM   #9
papa-t's Avatar
Glade Valley, North Carolina
[QUOTE=As another alternative, there are companies and a few individuals that rent FGRV's you might try that first ...QUOTE]
I agree maybe rent one first to see if you really like it first.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 04-30-2015, 06:33 PM   #10
honda03842's Avatar
Name: Norm and Ginny
Raj,
You have the first ingredient, a nice wife, some one to share the adventure with.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-30-2015, 06:57 PM   #11
Gilda's Avatar
Trailer: 2011 Scamp 13'
Be sure to follow Norm's advice. He not only adores his wife and lets us all know it, he is the guy to ask for trailer advice as he and his wife have been FGRVing for a looonnnnggg time!
While I do not have personal experience with renting FGRVs I found a few rental places in California. Where in California are you located?
Dan Ludovina
Located in Woodland, CA
Phone: (530) 219 - 2421
or email at dan@danstrailers.com
DansTrailers.com
Happier Camper
HappierCamper.com
rentals@happiercamper.com CALL: (470) 222-6728
We are located in Sunny Silverlake, Los Angeles at:
2756 Clearwater St, LA, CA, 90039
The Gleeful Glamper
Gilda (Jill-da)
Old 04-30-2015, 07:16 PM   #12
Raj loves in Florida
Old 04-30-2015, 09:34 PM   #13
David B.'s Avatar
And he LIVES there to.
Old 05-01-2015, 08:42 AM   #14
Paul O.'s Avatar
How much HANDY ???
Raj, maybe this already came up, but I think it would be good to point out that this forum looks to be mostly populated by people who are handy and take on a lot of projects. I am sure that a new, or a well maintained FGRV will provide many years of enjoyment without any complicated repair or maintenance. Unless there is an emergency, whatever is needed can be entrusted to some RV repair shop. Here we have something with wheels that we can still work on, modify, improve, many times not out of necessity, but because we enjoy doing it and may be proud of the results, and love to help others. I believe we are a small part of the population and most people simply enjoy using their trailers without regard to how "handy" they might be. Go for it!
Old 05-01-2015, 09:08 AM   #15
NASA42's Avatar
Exclamation
Raj....
A final add-on re: where to look for Casitas, Scamps, etc. on sale. Don't overlook EBay! They have a buyer protection offer, as well.
Back in 2013 we found our '07 Casita on EBay. Had to travel from central PA almost to Chattanooga, TN for the final inspection & purchase....and it was well worth it!
Frank
NASA42 is offline   Reply With Quote
Old 05-01-2015, 09:23 AM   #16
Ok..I'll throw my hat in the ring with this one.
OLD? NEW? Well, dont forget, the "New" eventually turns to "Old" and you will need maintenance regardless.
No one has mentioned this, but the worst I've found to deal with is the axle/wheels/bearings/tires. Why????
Without any ONE of those ingredients my friend, you WILL be left sitting on the side of the road! And that is not a good feeling. To me, this will be more critical buying "used" since you will have NO idea as to exactly how the suspension has been taken care of....unless someone you buy from has an immaculate maintenance record with the RV. And I've found that's rare.
If I was going to think about towing a used trailer and no knowledge of its history, I would pull the wheels and check the bearings. I would also take a CLOSE look at the tires. Even though the tires could be in excellent condition, their age can be deceptive. I bought my trailer new in 2010. I checked the other day, my DICO tires look BRAND new...but looking at the date on the side, they're now 7 yo!!! They were made in '08...another topic altogether.
Also...the axle...you can look and tell if the tires/wheels have been rubbing up in the wheel well. If so, that's a good sign that if it's a "torsion" axle (Dexter, Lippert, AlKo) that the rubber inside which supplies the "spring/shock" action could be worn out. Replacing an axle can get very expensive....not to mention new tires/wheels.
Not trying to scare you away, but these are REAL LIFE RV issues that many never think about until they're on the road and broken down!! Then it's too late and can lead to a traumatic experience.
Just be vigilant and prepared and it will be one of the most enjoyable ventures you and your wife will ever experience together!
Old 05-01-2015, 09:52 AM   #17
Handy Andy's... NOT
[QUOTE=Paul O.;519278]Raj, maybe this already came up, but I think it would be good to point out that this forum looks to be mostly populated by people who are handy and take on a lot of projects.
This group is sorta like the local Hospital, If you work there you might think that everyone in town is sick, when the patient count in an entire year might represent only1% of the service area.
It's been my observation that a small percentage, maybe less than 5%, do most of the asking and and even smaller number do the answering. The vast majority of FGRV owners are basically happy with their rigs and come here only when they have a problem, very, very few stop by to say "Everything's Great.
There is a huge member and visitor base that have been here for years and have yet to even make a single post simply because they haven't had that need.
What is seen here IS NOT typical of the overall FGRV community any more than a hospital is typical of an entire community. This is where the sick ones come for help, the rest may never have a need for a question.
That said, yes there are a lot of RV "Doc's" here, but the patient count is low and the survival rates are high.
Old 05-01-2015, 10:08 AM   #18
Trailer: Boler 17 ft
my purchasing mistake
Hi Raj,
All the advice given to you is bang on. I sold my 1978 15' Trillium that was in fantastic shape. It was owned by a mechanic who worked at Mercedes Benz and stripped it right down to and including the frame. He then put it back together and it was in fantastic condition.
I am still kicking my butt for selling it.
I bought and stupidly paid full asking price for a 1980 BOLER 17'. The sellers did a fantastic job of the inside complete with hiding water stains with mold retardant paint.
Well...within the first summer the bed frame collapsed. The water tank spotted tiny leaks and the musty odour started to creep in.Then a leak in the grey water tank.
Outside I need to replace the caulking around the windows and belly band and there is a hole in the awning.
None of this has actually taken away any of my fondness for this RV. The bed frame is being repaired, the mould has been cleaned up and newly painted. I have removed most of the caulking. I threw away the mouldy cushions and kept and cleaned their zippers.
I had a friend show me how to pack the bearings.
In a couple of weeks my friend and I are putting it up on a ramp and fixing the leaks.
I am getting a larger tool box for Mother's day! I bought myself a sewing machine to make new covers. The foam was expensive.
The folks at the equipment rental place in town now know me.
Had I not been so swayed by how great my Boler looked on the inside I would have noticed some of these issues and insisted at least on a safety inspection at an RV site.
Yes, I would still have purchased this unit
but for sure offered a cheaper price.
Because I am a single young senior woman who loves her FGRV and won't give it up I take it every spring to an RV center for a complete safety check, including the gas lines.Please do that.
My tow vehicle is a 2007 Grand Caravan with a class 3 hitch and I have a good electrical brake system.
Go for it Raj and have a great time.😀
Linda
Linda Stewart is offline   Reply With Quote
Old 05-01-2015, 11:20 AM   #19
Trailer: boler
very good points Linda. Raj, dont be afraid of the RV world. Most of us/them are willing to help if you have questions. Biggest concern as with Linda is routine maintenance. Like your car/van or truck, if you dont take care of it, it will break down. FGRVs are the same. Size of the rig you want will depend on what you are towing it with, what you want in it (full kitchen, bathroom with shower, queen size bed etc). The rest will come, just keep asking questions. When the time to buy comes along, take a checklist and someone that knows something about FGRVs.
slimmit is offline   Reply With Quote
Old 05-02-2015, 03:20 PM   #20
Thank you Guys & Gals, for taking the time to chime in.
I appreciate your comments, yes, I am a newbie, but take solace in the fact that every one starts at my stage & goes about learning from there.
The hospital & surrounding population was an interesting metaphor
Best regards
Handy tool Anders Laurits General Chat 4 08-18-2014 01:48 PM
Handy gadget with free shipping cpaharley2008 Care and Feeding of Molded Fiberglass Trailers 4 11-23-2013 08:55 PM
UHaul and other boondockers-here is a handy item! djtriceflt Problem Solving | Owners Helping Owners 6 10-06-2013 08:58 PM
How much is too much?? Pamela H Problem Solving | Owners Helping Owners 10 07-04-2008 09:47 AM
Handy Water Tote Ken James General Chat 24 08-02-2007 01:14 PM
