10-03-2020, 02:50 PM
#121
Trailer: Hymer
Saskatoon
Saskatoon Hymer
See pics attached. Saskatoon Hymer.
10-03-2020, 03:05 PM
#122
Trailer: Escape 19
Originally Posted by Bill Rafoss
Thanks for posting Doug VP. We have a Hymer touring GT and are concerned about the sway too. You likely have read all this, but we are trying to address it by - loading more up front, slow down, use a bigger tow vehicle (rental). We talked to some 'experts'. They say it might help to weld an A frame on the front so we can attach a weigh distribution system and sway bars. That is our final solution; trying these other ideas first. Heading out next weekend!
We tried a Blue Ox weight distribution hitch from eTrailer.com. There is a bolt-on T-bar onto which the arms of the hitch connect via chains. This hitch is then compatible w/ single spar frames, and also with surge type hydraulic brakes.
As for sway control, it worked very well. The problem we encountered is that the whole system hangs below the hitch/frame line, reducing the already poor ground clearance. This is not a defect of the hitch, but rather a misapplication. We removed it.
I then replaced the hitch/brake unit with one from eTrailer, one that adds at least 10" to the end of the tongue. ( https://www.etrailer.com/Brake-Actua...le/DX27FR.html) If this didn't work, I was going to add a folding hitch and 12" more length as well. As it turns out, the new longer hitch worked very well & I don't feel the need to add any more tongue length. Luckily, there was enough brake line and electric cord slack that was available to make this addition work w/o replacement or modification.
We do load the trailer with a bias towards the front, and keep the speed under 65. We just did a trip up the mountains and back, with a bit of freeway included and there was no sway whatsoever in 300+ miles in varying conditions, including crosswinds.
So, my 2 cents is - save your money on a WDH - unless you can find one that doesn't consume ground clearance - and change out the hitch connection for a longer one.
2013 Escape 19; 2021 Ford F150 Hybrid
"I hope something good happens to you today."
Previous trailers: 2008 Home built teardrop; 15' 1962 Robin Hood canned ham classic; 2019 Hymer Touring GT
10-03-2020, 04:38 PM
#123
Trailer: Trillium 4500
Heading out at Thanksgiving for one last Hymer trip. Loving it so far.
Would love to get a manual though. Will check these links.
Bill in W. Canada
Have you been to the official Hymer group page? They have a general Hymer manual and individual manuals for each of the systems.
https://www.facebook.com/groups/HymerGT
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe, Casita 16, Casita 17, Scamp 13' with bath.
10-03-2020, 04:39 PM
#124
PS I sold my Hymer last spring.
10-03-2020, 05:42 PM
#125
Trailer: Hymer
Saskatoon
Thanks
Thanks Steve!
10-10-2020, 12:01 PM
#126
Trailer: Escape 19
Oregon HYmer 2018 Touring GT
Some pictures (first time posting)
10-10-2020, 12:06 PM
#127
Trailer: Escape 19
Oregon Hymer 2018 Touring GT
A couple more pictures : added 2nd battery and selector switch; replaced hokey hitch/brake controller with longer, much improved version - lengthened tongue 10" - much improved towing stability, don't need WDH (also switched to pickup for TV)
10-10-2020, 12:10 PM
#128
Trailer: Escape 19
Blue Ox weight distribution hitch - effective for sway and leveling, but was unacceptably low - very little ground clearance. Shout out if you want it - very heavy to ship tho...
12-04-2020, 06:50 PM
#129
Trailer: Hymer
Nice. Very tidy.
12-14-2020, 08:54 PM
#130
Doug VP - thx for the tongue/brake actuator info. - i may have to go that route. i added a spare tire to increase tongue weight. already had the push/pull bar so just added a bracket. I also moved the battery/propane a few inches toward coupler. i have not tested sway since - so i'll see how it performs.
for others - sorry it took so long to get pics of the a/c duct changes but been a bit busy.
here they are - showing duct tape sealing of plenum to the inside/ changed attachment plates and new duct feeds/new 60mm and 3 inch ducts going up alongside sink drain/ 60mm duct to existing outlet and new 3" directable outlet above the drain access panel.
02-09-2021, 02:58 PM
#131
Trailer: Hymer touring gt
Electrical help needed
 Hi I’m new to the group so not quite sure if I’m in the right place. We bought a work in progress 2019 hymer gt touring trailer from the manufacturer bankruptcy sale in Kitchener Ontario. We have everything in place except the wiring and plumbing. If anyone has a wiring diagram or could take a pictures it would really help us out. We are kind of stuck.
02-09-2021, 03:13 PM
#132
Trailer: 2018 Escape 19
If anybody is interested there is one of these for sale in the Kelowna BC area on Facebook market place. They want around $12,000 and there is no interior.
02-09-2021, 03:16 PM
#133
Check out post #123 for a link to the Facebook group where it is said they have manuals.
Good luck on your build
02-09-2021, 03:50 PM
#134
Trailer: Hymer
Are you on the Hymer Facebook group? There's info on the KS2 inverter/charger (in the Files section) but we never found a factory wiring diagram. Pretty sure the Hymer Aktiv folks have a diagram for the vans. They share a few components and might be somewhat helpful, but obviously they are very different.
02-09-2021, 04:26 PM
#135
Thank you
04-08-2021, 02:26 PM
#136
Trailer: Erwin Hymer GT Touring
BC
Truma AC/ and Heat control help
Need some help finding a CP control and ac UNIT.
Mine did not come with it and I'm mid project.
any suggestions.
thanks,
04-08-2021, 02:53 PM
#137
Trailer: Hymer
No luck with Sam/Suiet Hacks or the guy in Canada who bought all the EHGNA remains?
04-08-2021, 05:09 PM
#138
BC
no, i need to actually buy a controller Truma CP controller.
Any idea about the AC unit controller?
04-08-2021, 05:36 PM
#139
BC
Sold it! Thanks for sharing.
04-08-2021, 05:46 PM
#140
Trailer: Hymer
No, but the AC controller appears to be a much simpler (non-proprietary??) deal.
Mobile Climate Control is the outfit that designed and built the GT's AC system. In the AC document (files section of the FB group...) they call it the MVC DIGITAL CONTROLLER. Looks like a pretty generic part. Or at least the sort of thing you could find a generic substitute for.
More info in the doc Air Conditioner - T384.pdf on the FB group. I tried to attach it here, but it's too large. Hope that helps.
