New Trillium 4500 Axle Available - Fiberglass RV
Old 10-10-2022, 01:39 PM   #1
Trailer: Trillium Manufacturing
Hi All:
I have 2 Dexter axles available, 2500 lb capacity for Trillium 4500s.
New, with warranty & Electric brakes
See TrilliumRV.com
Tom
TomA is offline   Reply With Quote
Old 12-14-2022, 03:23 PM   #2
Trailer: Trillium 4500
Hi, My 1979 trillium 4500 needs a new axle. I believe mine is original but can't be sure. It's welded on.
I have 10" drums showing Kelsey Hayes number 602026 and 027 on the backing plate for E-brakes and would like to reuse my drum with new backing plates I can get from e-Trailer for $100 if possible.
My outside frame dimension measured at the bumper is 53" and not 48". Were they built with that dimension as well?
My present hub face measurement is 68" and not 67".
I'm running ST175/80R13 tires already with the 10" drums.
My present starting angle is about 20 degrees up and barely an inch of play up and down and the trailer is very bouncy.
Will the axles you are advertising fit my dimensions?
Where are the axles located? I'm in the Detroit Area of Michigan.
What would the price be USD or CAD.
Lee Nyboer
cell/text 313-6713167
lnyboer@sbcglobal.net
lnyboer is offline   Reply With Quote
axle, trillium
New Trillium 4500 Axle! John in Michigan Modifications, Alterations and Updates 7 09-23-2017 05:45 PM
Best (easiest?) way to lift a Scamp 5er - New axle vs Axle-Less Trailer Suspension dreschool Towing, Hitching, Axles and Running Gear 7 06-26-2015 04:28 PM
Trillium 4500 replacement axle, specs request Tyhee Problem Solving | Owners Helping Owners 14 05-27-2015 12:59 PM
Sizing New axle for '79 4500 Trillium David Schroeder Care and Feeding of Molded Fiberglass Trailers 30 05-24-2010 07:58 AM
1979 Trillium 4500 - Still Available Nora Miller Classified Archives 29 05-01-2010 01:43 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
