Oliver camper - Fiberglass RV
Old 02-11-2017, 02:47 PM   #1
Oliver camper
What a great looking fiberglass RV
Legacy Elite II Travel Trailer | Oliver Travel Trailers
Old 02-12-2017, 06:19 PM   #2
DeanCHS1980's Avatar
Kentucky
Hey Darwin,
I would like a his and her set!
Take care,
Dean
Laura & Dean | '05 Casita 17' FD | '09 Kia Borrego Limited V8 2WD
DeanCHS1980 is offline   Reply With Quote
Old 02-12-2017, 06:53 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
What a heavy trailer.....which is why I didn't buy one. From Specifications:
GVWR
7,000 lbs.
Dry Weight (approximate)
4,600 lbs.
Charlie Y
Old 02-12-2017, 06:58 PM   #4
Kentucky
Hi Charlie Y,
They are made from white gold, which explains the weight!
Hey, I see you have an Escape 21'. Love that floorplan!
Take care,
Dean
Old 02-12-2017, 07:03 PM   #5
tractors1's Avatar
Upsized from a Casita 17LD when we both retired and the Ollie was just too heavy; didn't want to buy a big truck to pull it.
Charlie Y
Old 02-13-2017, 02:19 PM   #6
Heavy because of the double wall I suspect. They make both a tandem wheel and single axle models.
Old 02-13-2017, 03:16 PM   #7
Plus...they are a big user of "stainless steel"....no rust. I realize their frame is aluminum. They're built about 30 miles from me. They're basically a fiberglass "Airstream". But they DO look good inside and out!
Old 08-03-2017, 04:44 PM   #8
Trailer: shopping for an Oliver
The Olie II weighs about what a 22' airstream does, maybe even liter. Cant compare to a stick build.
Louisless is offline   Reply With Quote
Old 08-05-2017, 09:37 AM   #9
Trailer: Oliver
Oliver Legacy Elte
We recently received our 2017 18.5' Legacy Elite 1 from the Oliver Plant in Hohenwald. I chose the single axle for weight reasons (1000#s less than the LEII) not to mention that we fit very well in the floor plan. We wanted an easy towing TT that was structurally sound and offered us 4 seasons of camping. After testing all of the systems, we are very pleased with this Ollie and feel very confident in going about anywhere with it.
Cheers,
skalywag is offline   Reply With Quote
Old 08-05-2017, 10:44 AM   #10
Burro andTrillium are just a couple of examples of double wall construction which are really no heavier than their single walled counterparts.
Old 08-05-2017, 12:31 PM   #11
We really like the quality , fit and finish and smart engineering of the Oliver Elite ll .
The price is kind of steep but Oliver doesn't cut corners like some other high end FG trailers . When you add up the cost of an Oliver along with a 3/4 ton truck , you end up with a very sizeable investment. Something to ponder and dream about on a cold Winters night.
Old 10-18-2017, 09:47 AM   #12
Trailer: Escape 2013 19 ft
Hi Steve I have been dreaming of Oliver since the day I saw my first one . Wow so happy I can mention Oliver ! Pat
LindaandPat is offline   Reply With Quote
Old 10-18-2017, 10:52 AM   #13
If I follow the logic of many , an Oliver is too heavy only because their present tow vehicle is inadequate . By that reasoning if I owned a VW bug and could not tow a 13 ft Scamp , it's the fault of Scamp .
I have never chosen what FG trailer to buy based on the vehicle I own. If I bought an Oliver, then I need to have an adequate tow vehicle. If my present 1/2 ton truck was incapable of towing an Oliver , it's not the fault of the vehicle manufacturer or Oliver.
Old 10-18-2017, 11:00 AM   #14
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
The Oliver double wall construction with four actual pieces is really a huge advantage. The insulation is a big one, but it also means the tanks and tank plumbing are fully contained between the inner and outer bottom shells. This keeps them safer from freezing and it means much better ground clearance with no hanging down tanks or plumbing. With double walls, the inner and outer shapes are different, so the cabinetry can be largely moulded in and the interior doesn't have to be the same shape as the exterior with simply attached cabinets or wall coverings to add some insulation. All the interior walls are smooth fiberglass which can be simply wiped down if needed. The Olivers work well in very cold weather and have double pane windows too. The ducted heating system is routed in the space between hulls so the tanks stay warm in cold weather. All the fittings, like the grab rails, shore power plug and water connections are stainless steel. On my other trailers, I got tired of breaking plastic grab handles and other fittings after they were weakened by being out in the sun. The batteries are carried in a compartment directly over the axles on a slide out tray, so no extra weight on the tongue, which leaves room for streamlining and to open the truck tailgate.
Item after item just seem to be done well and easy to use.
I first saw mine when it was closed up and parked in hot weather, in the sun. Inside it was just warm, but not what I expected while parked in nearly 100 degree heat.
Raspy is online now   Reply With Quote
Old 10-18-2017, 12:12 PM   #15
On the contrary... we bought our Scamp 13' to "match" the truck I still have the- the '99 Nissan 4cyl Frontier. In 2010, it was only 11 yr old with apx 65K on it- still like brand new. Both our kids had just gotten married within the past 2 yrs of that.
We debated and discussed hours on end during 2009. We finally decided selling the truck, buying a larger one then a larger camper would be the thing. I ran figures in my head and came up with apx $40 to 50 THOUSAND dollars of investment.
I finally told the wife, NO, that's going against everything I've wanted and worked for. Everything was/is paid for, we're now "empty nesters" and going back in dept?????? Dont think so!! Because at the time, she had never really "camped". We didnt know if she'd even like it!
The conclusion of the matter:
I emailed her one day and told her, we could pay cash for the $13K brand new Scamp. Pull it with our current truck. NO payments. IF we didnt like it, we might lose up to $3K on the trailer if we sold it, but that would certainly beat a possible $20-30K loss on two new vehicles!!!
The year is now 2017- 7-1/2 yrs later. We still have the same truck (90K miles) and the lil Scamp. We just got back a couple of weeks ago from a short trip to McFarland Park CG in Florence, AL from spending a week there. We added the 12' CLAM and we're VERY happy and content with our current setup that we use at the MAX 2-3 times a year. It's not to say that I wont get a larger vehicle someday AND a larger camper- finances would be different now than when the kids first got married! . But, while not a decision many would have made in 2009, it's one that we BOTH were VERY happy and still happy that we did.
Old 10-18-2017, 12:44 PM   #16
Darell sounds like you are a great money manager . To tell my story I currently have now ,second owner1992 F250 with now 126,000 mi . I purchased second hand in 2003 and love my truck . The previous owner used to tow a boat . When we purchased truck it was for a second hand 1992 camper which we had for 10 years and sold for more then we purchased it . At first pulling our 2013 new Escape I thought was too much truck pulling lightweight trailer . Don't think that anymore . Look at new F 150 's and what they cost and until truck can't do the job will keep . Yup only get 9-11 mi towing . Can get 15 not towing . Pay a little more in gas with a V8 but all paid for . Cheaper tags and insurance also . I keep my truck up and keep improving our trailer , but everything paid for . Looking at the Oliver is just a dream and it doesn't hurt to have a dream .Pat
Old 10-18-2017, 03:29 PM   #17
Raspy's Avatar
Trailer: Roamer 1
Floyd,
How can that be with twice the number of shells and insulation between? Is it because the cabinets are molded into the inner shell? Did they make them even thinner?
Old 10-18-2017, 03:36 PM   #18
Cathi's Avatar
POBox 1267, Denison, Texas
X2. I feel that our tow vehicle is big already. And reaching the roof to clean it is another consideration.
Old 10-18-2017, 03:37 PM   #19
Originally Posted by Raspy View Post
Floyd,
I'm not Floyd, but two shells for the outside and two for the inside (and yes, the cabinetry is part of those), just like Burro and U-Haul created their trailers. Insulation is placed on the inside of the outside shells before they are all fiberglassed together.
Old 10-18-2017, 03:39 PM   #20
Cathi's Avatar
Originally Posted by DeanCHS1980 View Post
Hi Charlie Y,
Take care,
Dean
Dean, I am sure that you would appreciate the 21'. Great trailer and can customize so much.
oliver
Is the Oliver Elite II a Four Season Camper? Steve Outlaw General Chat 20 11-19-2014 08:22 PM
SOLD-2006 EGG CAMPER EGG CAMPER Pat B Ohio Classified Archives 9 01-18-2009 08:43 PM
