01-25-2017, 09:13 PM
Trailer: IN the market
Alabama
Oliver Legacy Elite II solar upgrade?
I'm researching the Oliver elite II trailer and was wondering if owners that have the upgraded 320 watt solar system are happy with its performance? I would also like to know if lithium batteries are an option, and if not why?
Thank you!
01-25-2017, 10:40 PM
Trailer: Roamer 1
Smith Valley, Nevada
I don't have the solar option on my Elite ll, but I can tell you that lithium batteries are not an option from Oliver.
Part of wether someone is happy with their solar option depends on their willingness to always park in the sun and being willing to regularly clean the horizontal collectors. Collector output is directly related to the orientation angle and flat is never the optimum angle.
Point is: Be careful with your expectations that may be based on rated output. They may be perfectly adequate for some and disappointing for others.
01-26-2017, 01:38 PM
Trailer: Trail Cruiser
A 320 watt solar system is a lot of power. I use a 100 watt system all summer with absolutely no problems but that will depend entirely on your power consumption.
Lithium batteries are fantastic but only if you have the right system for their application, otherwise you shouldn't use them.
As previously stated, max power is only sustained if your panels are oriented directly towards the sun which requires constant adjustment as the sum moves across the sky. If you calculate you power needs and double it, you can leave your panels flat on your roof and get sufficient energy.
Also, dust accumulation on the solar panels reduces the amount of light penetration and thus power output.
01-26-2017, 04:12 PM
Alabama
Thanks guys for responding. Tomorrow I get to check out a Oliver and can't wait!
01-26-2017, 08:05 PM
Trailer: 23 foot Oliver Elite II
I have the Oliver Elite II and have been traveling in it for 14 months from Canada to most points in the west. I have the 320 on the roof and have boondocked quite q few times. I have been without shore power for 7 days and probably could have stayed out more. We have an inverter to run the coffee pot and you can use the micro if its short. Its great but the issue becomes water after 3-4 days more than power. We love the Ollie we have put it through hoops.
01-26-2017, 09:28 PM
Alabama
That is awesome Bertus65! I do have a couple of honda 2000's I think would help out on those cloudy days when solar is not that great. I can see that water management would be key for extended boondocking. I could stay away from people for a long time but my wife not so much. We will compromise our trips and balance out our time as far as boondocking and rv sites.
Thank you!
01-26-2017, 11:28 PM
Good luck with the Oliver!
01-28-2017, 11:41 PM
Alabama
Thanks Mike! My wife and I were very impressed of the quality of the Oliver trailer. The outdoor temp was in the mid 40's and with just a small space heater the owners had the indoor temp very comfortable.
01-29-2017, 04:46 AM
Trailer: Oliver
New Hampshire
Geo777,
I have the 320W solar panels, 4 AGM batteries, inverter and optional street side awning. As a group of options, they allow me to dry camp in sunny locations without the need to run the AC. I have camped for one season in state and national parks without ever needing shore power. I have no generator.
It does require a working knowledge of the solar controller and solar monitor especially if your campsite is in deep shade. I have had no problems with dirty panels or the angle of the panels. Oliver Travel Trailer uses a PV array from Zamp Solar and they work well.
Keep in mind, the combination of options listed above are not cheap. If you think most of the time you will be plugged into shore power or using a generator, the solar components would be a pricy option without a great return on investment. On the other hand, if you plan to dry camp most of the time, it is a sweet setup.
An Ollie also has s special function called the EZ Winterization which can be used to easily replenish your fresh water supply without the need to break camp if you have access to a water spigot somewhere within the campground. When you combine that system with an RV tote tank for emptying your black/grey tanks, you can be a happy dry camper for weeks!
Buzzy
Buzzy
2016 Oliver Elite II - June 9, 2016
2016 F150 Lariat 3.5L EB, Max Towing
01-29-2017, 12:46 PM
Camping isn't cheap and hasn't been since I used a tent and sleeping bag but I enjoy it so much I consider it "good value" for the money I spend. I have been "boondocking" about 60 days/year for a lot of years. Now that I'm retired that will double. I carry a generator "just in case" but I've only used it once and it was expensive! $25 a day for fuel. Solar was expensive to buy but has paid for itself many times over and I don't have to source and pay for fuel.
01-29-2017, 07:36 PM
Alabama
Thank you very much Buzzy for that great info. I've noticed many people get price mixed up with quality and normally place price in front of value. Your insight was well taken and I've enjoyed how well you've put together youtube videos.
01-29-2017, 07:40 PM
Alabama
Like you Mike I'm also retired and never traveled this great land. I'm planning on doing quiet a bit of boondocking and see the value in solar. Thank you for taking time to respond and happy trails!
01-29-2017, 10:39 PM
Geo, enjoy your travels!
02-01-2017, 06:52 AM
Trailer: Oliver
New Hampshire
Geo777,
It is good to hear you are considering boondocking. In many ways, an Ollie is particularly suited to boondocking as well as off-season and solo camping. The solar option will help provide electric power and the EZ Winterizing will facilitate replenishing your fresh water. Both are helpful during extended boondocking trips. For off-season camping it is good to have a well-insulated camper, an Ollie meets that requirement. Sometimes life’s journey can take a turn where we do not have a co-pilot to help navigate our RV camping activities. Luckily, an Ollie is perfectly suited in both size and options to facilitate solo camping. I guess an Ollie has many capabilities to adapt to varying camping styles over the course of a decade or more. For me, it is nice to know I can change camping styles as needs arise and my Ollie will easily adapt.
Buzzy
PS - Thank you for viewing my YouTube videos.
Buzzy
02-01-2017, 10:54 AM
Winter camping can be a lot of fun if you are set up to do it, enjoy!
02-01-2017, 11:47 AM
Trailer: Roamer 1
Originally Posted by Buzzy
Geo777,
Buzzy
Nice post Buzzy, and you are so right.
We were camping in the Bristlecone forest at near 10,000 ft recently with no hookups. Nice campfire going and it was snowing hard. I finally decided to move inside and get warmed up.
02-01-2017, 10:21 PM
Alabama
Today my wife and I toured the Oliver plant and placed our order. We both were very impressed with all the folks at Oliver and can't wait until April when we take delivery!
02-01-2017, 11:33 PM
Trailer: Roamer 1
That is exciting!
You might go to the Oliver website and begin to poke around. It might help you make some final decisions about the details and fine tune your order.
02-02-2017, 06:03 AM
Trailer: Oliver
New Hampshire
Geo777,
Congratulations on the purchase of your new Ollie. Now the fun begins as you finalize the options. Reach out if questions arise. Hope you will consider joining the Oliver Forum. That is where Ollie owners support each other. The link below will walk you through the process to join. Hope to see you in the Oliver Forum Neighborhood. It's a great neighborhood. Seems to me, all the Ollie owners live on the corner of happy and healthy!
https://youtu.be/derweugXyE4
Buzzy
Buzzy
02-02-2017, 07:06 AM
Trailer: Oliver Elite II
Boerne, Texas
Geo777, glad to hear you have an Oliver in the works. We are really enjoying ours. As Buzzy notes, there is a lot of information over on the Oliver Forums. Mike
2016 Oliver Elite II #135 | 2020 Ram 2500 Laramie 6.7L Turbo Diesel
