Oliver math quiz - Page 5 - Fiberglass RV
Old 08-01-2021, 06:06 PM   #81
Originally Posted by gordon2 View Post
...I realize this is a bit vague so I will post a clue in the morning if it is needed.
Actually, I did include a vague clue in this post...
Ok gonna change plans.. here is an another clue. You should make no assumption changes regarding the pictures.
Old 08-02-2021, 08:29 AM   #82
..There is one assumption that, if changed, results in the correct answer being 209.
So the new puzzle is to tell me what different assumption makes the correct answer 209.
And this morning's clue:
Bill Gates is someone who might make the different assumption and then report 209 as the correct answer.
Old 08-02-2021, 07:03 PM   #83
Trailer: 2003 Casita 17' SD
Duluth,Minnesota
185
Randy Hagen is offline   Reply With Quote
Old 08-03-2021, 10:51 AM   #84
Yellow Boler's Avatar
3x=90
2y + 2y + y =25
,3z = 18
Y + X x z = Ans
X = 30
Y = 5
Z = 6
Ans = 210
Yellow Boler is offline   Reply With Quote
Old 08-03-2021, 11:10 AM   #85
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
Originally Posted by Yellow Boler View Post
3x=90
2y + 2y + y =25
,3z = 18
Y + X x z = Ans
X = 30
Y = 5
Z = 6
Ans = 210
Take a close look at the X in the bottom image.
Does it have all the Y and Z components?
AlanKilian is offline   Reply With Quote
Old 08-03-2021, 11:14 AM   #86
Jim Bennett's Avatar
As well, the math is wrong. The added before multiplying which is backwards.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-03-2021, 11:16 AM   #87
Raspy's Avatar
Trailer: Reboot 19.4
Smith Valley, Nevada
I can't find the "whipping a dead horse" emoji.
Old 08-03-2021, 11:30 AM   #88
I did agree with the answer of math spelled out gordon, something that was confirmed by you, I still feel one last post for all to read explaining the math is for some reason still necessary.
X = trailer (fully accessorized)= 90/3 = 30
W = wheel = 25/5 = 5
Z = door window = 18/3 = 6
The calculation given
W + X (missing some accessories) x Z
or
5 + ((30 - 10*two wheels - 6*window) x 6)
5 + (14 x 6)
5 + 84
Final answer
89
2017 Escape 5.0 TA
Old 08-03-2021, 11:43 AM   #89
I am actually appreciating that those late to the game are wrestling it through for themselves rather than peek at the revelation of the correct answer in previous posts.
When I was a math teacher, I sometimes taught the same class multiple times. Late in the day I found myself tempted to get impatient, forgetting that the problem was brand new to the students in the room.
A good math puzzle never dies. Let's not spoil the fun!
Here's a pretty good explanation of the rationale for the algebraic order of operations, which requires multiplication before addition in the last equation.
http://www.math.ucdenver.edu/~jloats...ationsSass.pdf
Old 08-03-2021, 11:44 AM   #90
Yes, my method was different but still got to the correct result. I thought I was being helpful by detailing the process (showing my work) but since the numerous confirmations of 89 being the accepted and correct answer have been ignored, I am sure my detailed post was ignored as well. Now to see if your final explanation is also remains unread.
There is so much information in this forum - you can find the answer to about any on topic question, and many off topic ones as well. You can lead a horse to water, but you can not make him drink.. and when he dies of thirst, you can beat him repeatedly.
I am actually appreciating that those late to the game are wrestling it through for themselves rather than peek at the revelation of the correct answer in previous posts. ...
Working on it before peeking is good but eventually one should want to see if their answer was confirmed already. I consider my explanation to be like you teaching math after your students have tried to work the problem. Except of course that my method is probably not the best approach and my students skipped class
I for one worked on it before reading any replies.. but I was sure to read the replies before posting, both to see if anyone else came to the same answer, and to see if I was being repetitive. I had three or four drafts before posting the work flow I used. And I have no problem admitting that there were two clues given in the posts that I needed to solve it.. before that I had all wrong answers.
Old 08-03-2021, 12:00 PM   #91
Raspy's Avatar
I don't know if people don't bother to read the repeated and clear explanation of how to solve the quiz, can't accept the order of math operations, or won't look carefully at the picture.
With all of the explanations given, is it better to blurt out the wrong answer, or try to discover how to get the right answer? Or even better, to suggest the right answer is wrong?
That's why this is fun. It reveals strategies, which include an insistence on lack of strategies.
Old 08-03-2021, 01:16 PM   #92
Massachusetts
That's why I always say people need to inflate their tires to the maximum cold inflation pressure, that they should twist their chains to shorten them and that it's just fine to run with a full tank of water with their refrigerator running on propane.
Old 08-03-2021, 01:41 PM   #93
210 is my guess
Smilinggator is offline   Reply With Quote
Old 08-03-2021, 01:48 PM   #94
I see what you mean.
Let me try again. It has half as many tires.
3x=90
2y + 2y + y =25
,3z = 18
Y + 1/2X x z = Ans
X = 30
Y = 5
Z = 6
Ans = 5 + 15 x 6 = 95
Note. Multiplication before addition.oops. Yes. I had fun trying to solve this without looking at other people's answers. Because that is more fun for me. Lol.
Old 08-03-2021, 02:41 PM   #95
Massachusetts
Y + 1/2X x Z = Ans
Why half of X just because it's missing two tires?
Now look REALLY CLOSELY at the camper in the last row and see if there are any differences between that and the top row campers.
Old 08-03-2021, 02:58 PM   #96
I noted that earlier and applied a value of 0 to that bottom trailer. Came up with 5 X 6 = 30.
And that's -30- for me.
Old 08-03-2021, 04:12 PM   #97
I saw that the window was missing as well. But the common theme in all 3 equations is its about the tires. So I only took that into account.
Old 08-03-2021, 04:21 PM   #98
I just thought of another way
5x + 5x + 5x =90
2y + 2y + y =25
,3z = 18
Y + 3X x z = Ans
X = 6
Y = 5
Z = 6
Ans = 5 + 18 x 6 = 113
If it's just about the number of tires
Old 08-03-2021, 05:14 PM   #99
Massachusetts
How is the "Z" equation about tires?
Old 08-03-2021, 05:46 PM   #100
To me it looks like tires on my phone. But I guess it could be windows. That would explain what you are talking about.
oliver
What roadside attraction is this? A Travel Log Quiz Adrian W General Chat 3 07-08-2009 06:54 PM
Name That............A Just for Fun ID Quiz Adrian W General Chat 9 06-30-2009 01:20 AM
Wiring Quiz Ami P Problem Solving | Owners Helping Owners 9 07-27-2008 11:42 AM
Driver's Quiz Benita Jokes, Stories & Tall Tales 2 07-18-2007 08:05 PM
Know It All Quiz Donna D. Jokes, Stories & Tall Tales 12 01-07-2006 10:49 AM
