This is the second time we have had the camper out, we got it last year and the intention is it would be a guest room at the house. We ended up with the
oxygen as not only is it cool, it is less than 8 ft wide, and I only have 7'10" at the narrow point go to behind the house. (this has yet to be tested, I think there will be about an inch clearance on both sides).
The door side with the
fridge cutouts, and the curved door
far side, with my new shore power plug. before this, there was a converter in the seat, but it didn't have a method of being connected.
Inside. The Table leg has been replaced with a telescoping mount. The converter can be seen, and the new plugs inside so that guests can plug in their CPAP machine. The cushions have the same fabric as other campers, so thats probably original.
Fridge and cabinet where others have a toilet
Large bed, with a passage, and a fan/vent above. Note there seems to be no
lights or wires, the fan is powered off surface mounted wires. This fan isn't factory, it is a normal 13" square that has been cut in. Unknown if there was one here before or if someone cut it in.
Above the table, another vent. This one looks factory, its moulded into the
fiberglass. Its 8x8, and
leaks. I need to replace this, but all the ones I have seen are much bigger, so I would have to cut it in like the other one.
View of the walkway to get to the bed. Seems other campers don't have this.
Stove and sink. In the cabinet there is a water jug, and the drain goes straight out the side. There is no tank.
View of the door, it is curved but also crooked. I can see why people would rather a flat door.
