Propane Regulator - Fiberglass RV
Old 07-10-2020, 10:46 PM   #1
Trailer: 1975 Surfside (not Triple E)
Propane Regulator
So I was on my trip and day 5 of 14 the regulator went. I am not a gas fitter and this was my first ever trip with a travel trailer and out of cell range, but it seemed obvious to me that the regulator was the issue. It is a basically new Fairview GasFlo 2 stage regulator typical setup (I believe).
So being out there a bit and panicking about my fridge and being able to cook I went to a hardware store and saw the single stage BBQ type regulators that reduce pressure to same 11" WC and decided to hack it into place, using the correct fittings, teflon tape etc of course. It worked like a charm and the trip went smooth. I was not worried about flow since I use much less than a BBQ in my surfside with no hot water. I was also down about 1/2 tank of propane and not super concerned about high pressure requiring a vent situation and I safely positioned everything while driving.
Cant find any information online on why you HAVE to use a 2 stage but to be safe I am ordering a new one .
So my question is: Did I do something horribly unsafe?
My main concern is that I am not certain the new 2 stage will be here before my next trip in Aug so I may need to consider using the same setup.
I did get cell reception at one point and checked and came up with very little information
kipper is offline   Reply With Quote
Old 07-11-2020, 12:48 AM   #2
Raspy's Avatar
Trailer: Reboot 19.4
Smith Valley, Nevada
I doubt you will ever be able to tell the difference in performance between a single stage and a dual stage regulator. Single is fine.
Probably the only time there would be a measurable difference would be under extreme flow rates or with extreme, high or low, tank temperatures.
Old 07-11-2020, 12:15 PM   #3
AC0GV's Avatar
Wisconsin
Yellow tape?
Originally Posted by kipper View Post
Teflon tape etc of course.
Did you use YELLOW Teflon tape? yellow tape is designed for gas-line use.
May not be a big deal out in the wind.
propane
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 03:29 PM
DUAL PROPANE REGULATOR - For Sale Marv Watson Classified Archives 0 09-15-2009 09:49 AM
Help needed for Campster lock and propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 11 06-09-2009 06:44 AM
Propane regulator Kevin K Problem Solving | Owners Helping Owners 9 04-24-2008 05:08 PM
Propane Regulator Replacement Don Nicodemo Problem Solving | Owners Helping Owners 2 08-06-2006 05:34 PM
» Trailer Showcase
Boler
robeye
Firefly
Sandy54
