Question about power converter - Fiberglass RV
Old 09-23-2021, 04:32 PM   #1
Weavery's Avatar
Trailer: Escape 5
I have a 2016 Escape 5.0. I have had it a year. Today I installed a new gas leak detector. We have arrived at our campground and the power convertor sounds like it is running a fan. Have never heard this before. ???
Weavery is offline   Reply With Quote
Old 09-23-2021, 04:47 PM   #2
Converters usually have fans.. the fans are often not heard because they are quiet and / or they only run under heavy load. My guess is your battery needed a good charge when you arrived and plugged in, so the converter was under a more than usual load and the fan turned on.
Old 09-23-2021, 04:52 PM   #3
Weavery's Avatar
Trailer: Escape 5
Thank you for your prompt reply. There is a reason I love this forum! I did turn off the kill switch which stopped the fan and it has not come back on since. I was running the frig on battery while we were on the road and your suggestion makes sense!
Old 09-23-2021, 06:22 PM   #4
The fan and motor collect dust bunnies and it might help to clean it and while you are at it, take some 3 in 1 oil and oil the motor. There is a little hole on each end with a felt washer inside that holds the oil.
Old 09-24-2021, 08:47 PM   #5
I don't think your battery will charge with the kill switch on. Running a fridge on 12v will kill the charge in the battery even while driving on most vehicles. I'd turn the switch back on and let the battery get a good charge. After it is fully charged the fan should stop and only run when a heavy load is put on it.
Question about Boler power converter desy Electrical | Charging, Systems, Solar and Generators 5 04-22-2013 04:53 AM
RV Power Converter 12 volt matt scott Classified Archives 0 07-19-2006 09:27 PM
FOR SALE: Power Converter w/ Panel Greta Martin Classified Archives 0 07-06-2006 03:07 PM
progressive Dynamics power converter Paddy Morris Problem Solving | Owners Helping Owners 4 04-30-2006 06:09 PM
Power Converter Legacy Posts Problem Solving | Owners Helping Owners 3 05-25-2003 07:02 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
