Removing paint on outside - Fiberglass RV
Old 08-21-2021, 04:28 PM   #1
ON
What is the best way to remove a bad job of spray paint from the outer shell? Stripper solvent or sanding or other options?
Micke is offline   Reply With Quote
Old 08-21-2021, 04:56 PM   #2
Depends on the type of paint. Start with the cheapest, easiest method and work your way towards harder. Don't sand blast, that will permanently damage gel coat.
Mentioned elsewhere I try acetone first. It will remove cheap spray paint. Test a small area out of the way, "start small, win big, start big, lose big."
Paint stripper is nasty stuff!
Old 08-21-2021, 05:19 PM   #3
ON
Thanks, I felt the stripper was too harsh as well. Just using my fingernail or putty knife scrapes it off.
Thx
Old 08-21-2021, 06:30 PM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Some successfully use green pad with soap and water.
I recently used some old citristrip on a small area. It worked in a few minutes and then I had to remove and clean the surface.
Old 08-21-2021, 07:00 PM   #5
tractors1's Avatar
Trailer: Escape 21 - Felicity
MEK (Methy Ethyl Chloride) is a good paint stripper that won't hurt gelcoat, but don't get it on anything plastic as it's a fine solvent for that. Home Depot, etc.
Also not good on asphalt or lawns.........it's going to be a messy job. When I stripped a trailer I got a whole bunch of cardboard boxes to put under it. Wear throwaway shoes.
Charlie Y
Old 08-22-2021, 03:09 PM   #6
Borden's Avatar
Name: Borden and Carole
Thanks
This could help us, we have a painted flower to remove
paint, vin
Removing paint on outside Micke Problem Solving | Owners Helping Owners 2 08-14-2021 03:08 PM
Paint on outside Patricia D. Problem Solving | Owners Helping Owners 8 07-09-2016 08:24 PM
removing paint on outside of trailer... April Wilcox Problem Solving | Owners Helping Owners 5 10-19-2008 07:17 AM
removing paint from Boler outside Judy Powell Problem Solving | Owners Helping Owners 1 07-10-2007 11:01 AM
outside paint job Legacy Posts Problem Solving | Owners Helping Owners 11 04-04-2003 08:44 AM
