11-20-2008, 06:50 PM
I think, as an old retired engineering prof, that the most annoying thing about my egg (Casita) is the riveting. It is so crude and ugly. I suppose it is economically necessary in that that screws that didn't pop could very well stress to cracking (fracturing) limits thus rendering the hole a diameter or two larger than designed. Nevertheless they are... as I said....ech.
Nothing against rivets. Without them Boeing would be doing something else but still they are ugly.
I think I saw that the Escape or some other egg, having dual walls that had metal frame sections within the walls where the "furniture" could be attached rigidly with common screws, were better suited to solid riveltess construction.
Comments?
11-21-2008, 12:02 AM
I think you hit the rivet on the head with the word ... economical.
I was given some aircraft grade rivets by a friend, I could barely get them to work with the hand unit. They simply took too much force to use. Went out and bought some regular "pop rivets" to finish the work. I've even tried some of the SS bolts with washers and the nylon lock nuts. Much more expensive, and install best with 2 people.
From an engineering perspective, I'm surprised they don't use FG raceways for conduits and strength.
11-21-2008, 08:45 AM
Administrator
Trailer: 2015 Escape 21; formerly Casita 1999 17 ft Liberty Deluxe
We've had lots of discussions on the pros and cons of rivets. Do a search on the "care and feeding" forum; you'll probably find lots of opinions on the subject.
11-21-2008, 09:16 AM
Trailer: 1974 Trillium 13 ft
I think it should be fairly easy to cover ugly rivets with plastic screw caps for inside use, or perhaps a dab of resin.
11-22-2008, 06:51 PM
Trailer: 17 ft Casita Liberty Deluxe
Hi Ron,
Lucky for me I don't mind rivets and how they look. Considering where I have towed our little Casita (coming off the Hopi Mesas on our recent trip in a 75 mile an hour head wind from the hurricane in Mexico as an example) I am amazed I haven't popped more of them!:-) Got to get our baby washed and cleaned up for the cover and a winter nap soon...but strangely enough too cold here in SC lately!
Rand:-)
11-24-2008, 08:52 PM
Hi Ron,
Rand:-)
Oh I was being coy. Of course they work but they are ugly... like a bunch of little white zits poking out of the skin. Just ugly. Which fiberglass RV has no rivet pimples? any?
I have many times pulled my egg over 60 miles (one way) of the toughest rock roads in the United States (to toroweep grand canyon) and have popped only one rivet. But I am kinda like a wincing mechanic. I drive very slow and careful and just cringe when the bump feels too hard. It is stressful.
11-24-2008, 10:33 PM
The 1970s Trilliums basically have no rivets (I think they have a half dozen holding the rain gutter on over the door, and maybe a few others, but none to speak of.) I don't think the Compact Jrs have very many either. In addition, I don't think the Burro/U-hauls have any (?)
Raya
11-24-2008, 10:40 PM
Comments?
Olivers have a double hull, high gloss marine grade gel coat in and out. No rivets. The furniture and cabinets are molded into the inner hull. The reinforcements between the hulls, where necessary, as well as the frame, are aluminum. Perhaps this is the brand you're thinking of. I believe (though I've never seen one in person...) that the Escape is single hull, evidenced by the vinyl liners, side-mount A/C, and non-fiberglass cabinets in the website. Is that correct?
11-25-2008, 09:43 AM
I have a rivet question, while we're on the subject. (I've searched the archives but not found this.)
Usually, in houses, boats, etc. it's considered somewhat second-rate if you re-paint the outside, and, instead of removing hardware, simply paint over it. I'm thinking of door hinges, doorstops, and other fasteners.
On something like a Scamp or a Boler, let's say you were getting ready for a nice paint job, so you were removing the aluminum windows, and then either removing or masking off other hardware (belly band, black window gaskets, door hinges). Okay, but what about the rivets? Would the proper way be to remove (yikes) them all? Would one mask them off? Paint right over them? Same question would apply to the truss heads if one had replaced their rivets with screws.
I know they make those plastic rivet covers, but I'm not fond of the way they protrude so those wouldn't be in my equation.
(I'm not planning any large painting projects, but this question popped into my head the other day after reading this thread and so I'm curious. )
Raya
11-25-2008, 05:59 PM
If one removes all the rivets from one interior fixture, one might have trouble getting it all back together so the holes match.
There are two answers to your dilema:
1. Strip everything out, use epoxy and glass tape to install elevator bolts to the inside walls for fasters, then fill the former rivet holes from the outside. Or just use glass and epoxy to fiberglass the inside of it all to the inner walls.
2. Get one of the doublewalled trailers like Burro, etc.
11-25-2008, 06:30 PM
Trailer: 2000 24 ft Shasta Ultra Flite
Pop rivets have many uses although I don't like where they are used on my trailer when I put up new blinds and removed the old curtain rods I drilled out the rivets and replaced them with SS screws and SS finishing washers.
11-25-2008, 07:07 PM
Hi Pete,
I understand about using fiberglass tabbing instead of rivets, as I use that method on boats. I think it would be superior, but was probably not done at the factory becuase it would be more labor intensive (i.e. more expensive), and the rivets do work.
I was asking about if one was going to keep on using rivets or screws/nuts, then what does one do with/about the rivets when painting the outside of the trailer (as compared to removing or masking off other metal hardware).
I'm still curious.
11-28-2008, 07:38 AM
Trailer: 17 ft Escape
We have an Escape and no there aren't any rivets. The mold is such that the cabinets can be attached internally. We have taken ours over some rough roads and long journeys and we haven't had anything pop or come loose. We love ours!!
11-11-2011, 11:46 PM
Trailer: 13' Scamp
SS hardware
Stupid questions:
1. How does one go about "drilling" out a rivet without ending up drilling holes in the camper. I assume you try and pull out the rod sticking out of the middle of it from the outside and then drill into the void...
2. If you are putting in screws on the outside, what is holding up the curtain rods. and if you are using screws are you just screwing directly into the fiberglass?
3. Very new at this, still a little nervous about putting holes in "dream camper."
11-12-2011, 08:34 AM
Trailer: 1986 U-Haul CT13 ft
U-Hauls and Burros are rivet-free. The double-hull construction features molded cabinets and furnishings on the inside, without any through-fasteners needed.
11-12-2011, 09:13 AM
If you wish to rivet fiberglass you should use aluminum rivets,fiberglass can be crushed using stainless steel or carbon steel rivets. The riveted cabinets install best with two people as well.
The word "economical" should be replaced with the word "versatile". It allows for custom work like my 13 deluxe which can't be had from any other source. My trailer is nearing 8 years old... check back with me in 25 years to see the best value possible in excellent condition! (IF I'm Still around)... otherwise you will have to check with the guy who pays a premium price to my estate for a trailer which he can treasure for many more years!
11-12-2011, 09:42 AM
I have a deluxe Scamp with7-1/2 years and 50,000 plus miles on it, and not one defective or loose fastener through the hull.
Of course esthetics are subjective, but your characterization is a bit silly and extreme. As far as function is concerned, I have owned all sorts of fiberglass trailers and the riveted trailers have held up as well or better than any others. If you are popping lots of rivets when towing then you would be damaging any other trailer through the same type of abuse.
I have owned several Scamps over 30years old in every condition imaginable and I can tell you the rivets are not an issue when it comes to refitting an antique fiberglass trailer.
11-12-2011, 09:43 AM
Trailer: 16 foot Scamp
I think Scamps use of rivets is rather ingenius to be honest. So far I have had one broken rivet and my trailer has seen a lot of flexing and bouncing. It could have even been a pre-existing defect that caused it. They set them into acorn nuts on the inside which I think was pretty clever. As Floyd mentioned, it gives them a lot of freedom to accommodate our custom wishes. One major reason I bought a Scamp was because of that ability and willingness. Rivets have some unique qualities as well. They are not simply inferior to bolts. For one thing, they maintain tension extremely well, and the tension they exert is very uniform from one to the other. To get that kind of precision from a bolt would require a torque setting driver on each one. If the rivets were replaced with bolts they all have to be loctited or fitted with locking nuts. Rivets fill the holes they occupy, but bolts do not. That means that bolts have to create all their bonding and locating strength through clamping force. If the clamping force is insufficient, the panels will shift and the holes will enlarge even more. If the clamping force is too great the glass can crack. Something to consider when bonding materials like fiberglass. I could go on and boar everyone to tears, but you get the idea .
I do agree the shell would look better perfectly smooth, but rare is the advantage that comes without compromise.
David
11-12-2011, 09:58 AM
Surprising, considering the frequency with which rivet issues are raised in this forum! Rivet breaks, leaks, and replacements have often been discussed over the years I've been in this forum.
11-12-2011, 10:14 AM
Trailer: 1976 Trillium 1300
I had a quick question re: rivets. On my 2010 Scamp on the outside it looks like the factory puts silicone or something similar under the caps. It is already coming off on several rivets. Is this something you have to redo every year and if so what is the best stuff to use for it.
I must confess I much prefer the clean look of the Trillium with no 'pimples' on the outside.
Thanks.
