Screws sticking out of floor bottom - Fiberglass RV
Old 11-22-2021, 09:27 AM   #1
Trailer: Scamp 13’
Wisconsin
There are many self tapping screws sticking out of the bottom of my 2020 Scamp 13. I like to store my Clam under the trailer (propped up off the garage floor on plastic trays), and it tends to snag on these screws. Can I just snip off the protruding parts of the screws?
sunnyone is offline   Reply With Quote
Old 11-22-2021, 10:03 AM   #2
Don't see why not. Snip and give 'em a few swipes with a file to eliminate burrs.
Old 11-22-2021, 10:35 AM   #3
Trailer: 2013Escape 21
Iowa
Screws
Then give each one a shot of aerosol plasti-dip to seal them and make sure you can locate them in the future if need be.
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 11-22-2021, 01:10 PM   #4
Trailer: Scamp 13’
Wisconsin
Thanks, guys.
Old 11-22-2021, 01:38 PM   #5
I have zipped a bunch of them off with a cutoff wheel.
Dremel or grinder. Much smoother cut than a nipper.
If you scuff the paint , simply touch it up with a rattle can or a brush.
Old 11-22-2021, 03:40 PM   #6
Trailer: Scamp 13’
Wisconsin
(I don’t know what the question marks are for. That was supposed to be a thumbs up emoji.)
Old 11-22-2021, 06:27 PM   #7
Use one of these, squeeze hard then wiggle back and forth and the screw will break off. This is a special tool that is handy to have in your tool box.
https://www.amazon.com/Bates-Remover...a-855517345164
Old 11-22-2021, 06:51 PM   #8
Name: You can't call me Al
Trailer: 1977 Scamp 13'
Massachusetts
While wearing safety glasses.
-Safety Sam.
AlanKilian is offline   Reply With Quote
Old 11-22-2021, 08:19 PM   #9
I've got six or eight of those things. It was the essential tool for the BTs in the refinery. It will work as you describe, but I caution that wiggling back and forth can loosen the screws in the wooden floor if your not careful.
Cut-off wheels are much quicker and easier and make cleaner cuts for this application.
Old 11-23-2021, 07:28 AM   #10
Trailer: 2008 Casita 17' SD
And while you're under the trailer with the touch-up paint, I would surely recommend sealing that raw unfinished, (and unsealed,) MDF particle board flooring to keep it from soaking up moisture and turning into a weak bloated swollen expanded sponge. I can't actually believe that they would have exposed wood under the trailer that wasn't coated to seal it from water intrusion. That MDF will wind up being mush if you let water get into it.
Old 11-23-2021, 07:57 AM   #11
Greg, it’s OSB, not MDF, and it was sealed at the factory with a coat of fiberglass resin. It’ll be fine, as long as the OP keeps up with basic shell maintenance, doesn’t let mud and crud accumulate on the undercarriage, and deals promptly with any leaks that develop from windows and other shell penetrations. 99% of floor rot happens from the top down.
Mine is now 13 years old and the underside of the floor looks nearly as clean as the day it rolled out of the factory.
Old 11-23-2021, 04:16 PM   #12
Well, OSB, MDF, Plywood, etc. It just looked like the picture was showing a raw piece of wood panelling. If it is coated, fine, it just didn't have that appearance from the picture up above.
Old 11-23-2021, 04:22 PM   #13
Good news is, You don't actually have to believe it....
Two points...
1] The floor is sealed from below with the same type of polyester resin used to make the fiberglass.
2] It is OSB (oriented strand board) NOT MDF.
OSB is the same stuff that houses are made of .... floors, exterior walls, floor joists, roofs, etc. All "unsealed".
Old 11-23-2021, 04:26 PM   #14
Old 11-27-2021, 11:11 AM   #15
Trailer: scamp
Indiana
Should not be a problem. But I would not do it right at the floor. I would leave like 1/16 of an inch or so still sticking out. That way the full function of the screw is maintained.
computerspook is offline   Reply With Quote
Old 11-27-2021, 01:13 PM   #16
Trailer: Scamp 13’
Wisconsin
Good idea.
Old 11-27-2021, 03:35 PM   #17
Trailer: Miti Lite 1987
Whack em flush with a hammer.
Peder_y2k is offline   Reply With Quote
Old 09-14-2022, 09:38 PM   #18
Trailer: Northwood Nash 22/1977 Trillium 4500
Why weren't these cut off at the factory?
What the hey? Couldn't they have cut these off at the factory so they are not a snag hazard. I went and looked under our Northwood and there is no such thing there. I have been under our other trailers and have never seen such a thing. Did they forget?
Shangie is offline   Reply With Quote
Old 09-15-2022, 06:30 AM   #19
My main concern would not be with the screws but with the untreated OSB plywood in the photo ,I would definitely coat that with gravel guard or at the least a exterior heavy coat of paint .
Mikmay is offline   Reply With Quote
Old 09-15-2022, 06:54 AM   #20
It is not untreated, as has been said several times already. And apparently it works, because I have yet to see a Scamp floor that rotted from the bottom. All the rot I've seen has started from the top, caused by neglected leaks from windows, vents, and plumbing.
The screw tips have not been a problem, other than you have to use some care when working under the trailer. My 2008 originally sold for $7500, and I took a few rough edges here and there as evidence of some economies in its construction. At the prices they're charging now, they might at least nip off those sharp tips.
Sticking the landing? Floor question Old Macdonalds Problem Solving | Owners Helping Owners 10 04-18-2021 06:21 AM
Sticking on the decals Pam Garlow Care and Feeding of Molded Fiberglass Trailers 14 07-07-2015 05:36 PM
Covering wood screws sticking out mgellar Problem Solving | Owners Helping Owners 3 04-21-2015 06:35 PM
Sticking TO ensolite, non-permanent Tonia Problem Solving | Owners Helping Owners 2 09-07-2012 06:38 PM
Sticking ensolite back onto shell Peggy Problem Solving | Owners Helping Owners 1 09-20-2010 07:53 PM
