Trailer Valet XL and tight turns? - Fiberglass RV
Old 07-28-2017, 08:36 AM   #1
Trailer: Parkliner 2014
Georgia
Anyone have experience with a Trailer Valet XL and tight turns? https://www.etrailer.com/Carts-and-Dollies/Trailer-Valet/TVXL2.html
Preferred storage is my house but we'll have to see what the county's tape measure says. Second preference would have two right angle turns - left then right - in short space (paved); a car would be ok but to back a trailer "you'd have to be real good" and I'm a novice. (Third preference has only business hour access, which isn't great but ok.). Single axle up to 17' ( Parkliner experience particularly interesting.)
If you've had good experience on pavement, any use in a campsite?
Thanks.
FishingBob is offline   Reply With Quote
Old 07-28-2017, 11:35 AM   #2
Trailer: Shopping
Ohio
I have an Escape 21' with dual axles and the XL. I bought it particularly to make a sharp swing from it's storage spot to bring the trailer out for hookup to the Silverado. To go sharply sideways requires a lot of force with dual axles. The XL put so much torque vertically that it bent the lip of the coupler. I was able to straighten it with a big adjustable wrench. It works great on less radical turns. I think slopes would be a problem. I defaulted back to using a 2' hitch extension to swing the trailer out then removing and hooking up normally.
If you are single axle you would be fine as long as no steeper grade.
CarlN is offline   Reply With Quote
Old 07-31-2017, 10:05 AM   #3
richardr's Avatar
Trailer: Escape 21
I use a Valet XL with a Casita FD17. I have to move the trailer sideways about 4 feet by going up and down the driveway which has a 3.4% grade, (according to my phone level). It works, but it is not easy and I wouldn't want to try a steeper driveway. We are getting an Escape 21 next month. I expect moving the trailer into position with the Escape will be quite a bit more difficult.
richardr is offline   Reply With Quote
Old 07-31-2017, 10:02 PM   #4
Trailer: Scamp 13
Get a Power Caster or make one if you have skills. Then you can manuver anywhere you want.
Power Caster Inc | The Original Trailer Mover | Temple City 800-773-3833
Keeping your trailer at home is the only way to go.
if you build one you can go 12 volt and power off the trailer battery. Power caster powers off a cord at your house.
Trailer Valet - Has anyone used one of these? Sandy54 General Chat 37 04-23-2017 04:31 PM
Trailer Valet, Have you used one? Gilda Towing, Hitching, Axles and Running Gear 10 08-03-2014 09:05 PM
Trailer Valet Rep here Trailer_Tyler Hi, I am.... 3 09-17-2013 12:31 PM
Trailer Valet Thane Care and Feeding of Molded Fiberglass Trailers 15 09-11-2013 05:07 PM
RVing Turns 100! Patrick M. General Chat 2 06-08-2010 02:11 PM
» Trailer Showcase
Acorn
robeye
Award
cynnbad
