Trillium Furnaces - 11HU - Fiberglass RV
Old 10-13-2020, 01:53 PM   #1
David Tilston's Avatar
Trailer: Trillium 4500 - 1976, 1978 (2), 1300 - 1977, 1973, and a 1972
My friend Mike purchased Humpty Dumpty from me. This is a 1973 Trillium 1300. The furnace in this age range is different from the 65810-002 in later model 1300s. I have a spare furnace for this trailer, so I figured I would do a tear down of it.
First off, it has the same gas valve as the other Duo-Therm furnaces in Trilliums. The ITT RV18AA. The following pictures are from the tear down.
It is not supper obvious, but there is some fancy duct work on square outer housing. The exhaust pipe is surounded by the combustion air inlet. At the fire box end of the exhaust pipe, where the gasket and it's holder can be seen, there is a space, between the two layers of metal, that ducts the incomming air to the bottom of the combustion chamber/heat exchanger. Inside the combustion chamber, just below the exhaust pipe, is a baffle that slows the flow out of the exhaust. I assume this is to keep the hot gasses in the heat exchanger longer so more heat is transfered to the inside of the trailer.
furnace, trillium
Trillium Furnaces - ITT RV18AA02 David Tilston Care and Feeding of Molded Fiberglass Trailers 7 08-19-2018 01:46 PM
Trillium Furnaces - 9-3608 Blower David Tilston Care and Feeding of Molded Fiberglass Trailers 6 06-05-2018 08:00 AM
Lighting pilot of Duo-Therm 11HU furnace Barrie Bochoff Problem Solving | Owners Helping Owners 3 07-16-2010 06:06 PM
» Trailer Showcase
trillium
spud
Trillium
Lise S
