3 way Fridge Disposal - Fiberglass RV
Old 07-08-2020, 03:39 PM   #1
Trailer: Fiber Stream
Hi,
Has anyone drained the ammonia from a fridge cooling system? I would like to dispose of my dead fridge but local transfer station wants it drained.
Thanks,
Steve
slbran is offline   Reply With Quote
Old 07-08-2020, 06:31 PM   #2
IllAnnoy
My guess is that the "transfer station thinks it has freon in it.
Ask your local RV shop, they may even take it for free to repair it or use it for parts.
Or at least they may drain the ammonia if you don't want to do it or are not sure how.
Old 07-08-2020, 06:42 PM   #3
I agree that someone will likely want it. But "draining" it is an interesting question. I looked around the net and found no direct answers. However there was this story from someone who had a number of absorption fridges he needed to dispose of...
Yellowjackets line piercing tool will only work on copper lines but not on steel lines so I made a saddle, nipple welded on, attached ball valve and a fitting for a hose. I open the valve, put a drill through it and tap the line. I withdraw the bit enough to close the gate valve. I lose some ammonia but I am wearing a full face cover and and gas mask. I did 40 or fridges and then had one flare on me... 8 feet straight out; lasted only a second. That got my attention. I did a couple more and then when I tapped a small fridge and the ammonia came out, it exploded. No harm done but it puts this procedure on hold.
So I a thinking a large open field and a high powered rifle.
Old 07-08-2020, 08:37 PM   #4
Okay, thanks for that info. I looked on the web but could not find anything. The fact that it can explode out is not something I want to experience.
I also wonder if any pressure in the system is gone since the ammonia was leaking. It was bad enough with the door closed. That is the reason I removed it because I wanted use the trailer and was getting it ready for a trip when it started to leak and smell. Had to wear a respirator while getting it out.
I was thinking of using a drill but that sounds risky now.
Thanks
Old 07-09-2020, 02:43 AM   #5
Raz
Raz's Avatar
Vermont
The reason I won't drive down the road with my fridge on gas is not because of the propane but rather that hydrogen gas is one of the components in the refrigerant. Perhaps that's what's exploding?
Old 07-09-2020, 05:06 AM   #6
Steve Hammel's Avatar
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
Post it for free on Craigslist or Marketplace. Someone somewhere will always want it for whatever reason. Put it on the curb with a sign that says free and post it online. State that they don't need to come to the door just take it. Always works for me and if someone can use it better than being put in a landfill.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT
Old 07-10-2020, 03:34 PM   #7
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
I too my old Dometic fridge to a local scrap yard. They took it, no questions asked.
I don't think Ammonia is toxic.
What's that about hydrogen? You better look up how absorption fridges work.
Old 07-10-2020, 04:30 PM   #8
Raz
Raz's Avatar
Vermont
I already have.
https://en.m.wikipedia.org/wiki/Absorption_refrigerator
Excerpt: The refrigerator uses three substances: ammonia, hydrogen gas, and water. The cycle is closed, with all hydrogen, water and ammonia collected and endlessly reused. The system is pressurized to the pressure where the boiling point of ammonia is higher than the temperature of the condenser coil (the coil which transfers heat to the air outside the refrigerator, by being hotter than the outside air.) This pressure is typically 1416 atm at which pressure the dew point of ammonia will be about 35 C (95 F).
Old 07-10-2020, 09:50 PM   #9
tractors1's Avatar
Trailer: Escape 21 - Felicity
Originally Posted by Raz View Post
I already have.
Excerpt: The refrigerator uses three substances: ammonia, hydrogen gas, and water. This pressure is typically 14–16 atm at which pressure the dew point of ammonia will be about 35 C (95 F).
That's 235 psi for the curious folks. Typical scuba tank pressure is 3000 psi.
Charlie Y
Old 07-18-2020, 11:40 AM   #10
mamusa
Be careful with the fridge. I accidentally punctured a line when I was removing the fridge and it was not pretty. Besides an oily mess where the compressed gas escaped, I got some on my face and received burns from the ammonia.
mamusa is offline   Reply With Quote
Old 07-18-2020, 02:09 PM   #11
Trailer: scamp
Indiana
Why are you disposing of it? Usually the reason it doesn't work is that the amonia has escaped.
computerspook is offline   Reply With Quote
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
Portable Waste Disposal Tanks Steve Dunkel General Chat 4 11-26-2009 11:39 AM
Garbage Disposal in Casita General Chat 0 01-01-1970 12:00 AM
