84 Bigfoot 17' body care - Fiberglass RV
Old 12-19-2020, 01:08 PM   #1
Trailer: Bigfoot 17'
WINNIPEG
Hello everyone. Come spring I'm looking to polish up my dull 84 Bigfoot 17' trailer. The Mr Clean pads work excellent to clean it but can I polish it up to give it some more protection? Any help would be great. Happy Holidays everyone.
Yogibengal is offline   Reply With Quote
Old 12-19-2020, 03:00 PM   #2
Trailer: 1986 Bigfoot B17 dlx
I used New Glass 2 on a motorhome & was well pleased, I plan to use it on my 86 17ft look up factory info
rogerfb is offline   Reply With Quote
Old 12-19-2020, 04:52 PM   #3
Trailer: 28' Bigfoot Silver Cloud
Woodstock, IL
We use PoliGlow on our 1988 Bigfoot each spring.
Old 12-19-2020, 08:48 PM   #4
WINNIPEG
Thanks for the tip.
Old 12-19-2020, 08:49 PM   #5
WINNIPEG
Thanks
So the Poliglow is it easy to apply and I take it is shiny after?
Old 12-20-2020, 06:40 AM   #6
Woodstock, IL
To use PoliGlow, the trailer must be washed first. Then, 3x3 sections are done with a light coat of PoliGlow. It dries very quickly, and the section is repeated until 5-6 coats have been done. Then move on to the next section until the trailer is completed. It is left with a shiny, wet-look finish. Note: Some folks use Zep wet-look floor polish instead (cheaper!). Same application process. Check out the threads about this for more info. Iíve used both and find the PoliGlow stays shiny a bit longer in the upper Midwest. YMMV.
Old 12-20-2020, 08:00 AM   #7
WINNIPEG
Thanks for the info
Old 12-26-2020, 12:35 PM   #8
buffing out glass first
I was reading around threads like this and decided to give my '89 17' Bigfoot a good buff out first, then polish with 3M marine polish, as some have advised.
Santa brought me a Porter Cable side-angle buffer with a good quality hook and loop buffing pad as the base for different pads. Some have advised to be very careful to not burn through the thin gelcoat with a rubbing/buffing compound.
I'll start with the cover over the propane tanks, should I have a technique 'malfunction'.
As an aside, I've done the multi-Zep treatment on an earlier Class C RV fibreglass end cap, and it did work great. It lasted close to 3 years, and then was pretty much gone.
Bob T.
Victoria BC
Bob T is offline   Reply With Quote
Old 12-26-2020, 02:26 PM   #9
WINNIPEG
Bob T.
Victoria BC
Thanks for the info
Old 12-26-2020, 02:26 PM   #10
WINNIPEG
Bob T.
Victoria BC
Thanks Bob.
bigfoot
Battery care John and Nancy Hamilton Care and Feeding of Molded Fiberglass Trailers 2 10-19-2007 09:47 PM
Wax and fiberglass care - AGAIN Donna D. Care and Feeding of Molded Fiberglass Trailers 12 06-13-2007 06:26 PM
Would anyone care to join me? Gina D. Camping, Campout Reports 0 05-17-2006 10:30 PM
fiberglass care questions from newbie ChrisB Care and Feeding of Molded Fiberglass Trailers 13 03-23-2006 12:25 PM
Exterior Care Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 01-23-2003 02:43 PM
