Ants - Fiberglass RV
Old 04-19-2025, 06:13 PM   #1
Trailer: Bigfoot 25RQ
Ants
We are on a trip and at the latest campground we were invaded by tiny ants. I had recently resealed everything underneath so I was surprised they were able to find a way in. It took awhile, but I finally managed to track down how they were getting inside. The ants were traveling up a rear stabilizer jack and along the top of the frame, nearly all the way to the front of the trailer. Where the fiberglass meets the steel frame everything is nice and tight and there is no access. However, there is a several inch long piece of rubber between the fiberglass and steel, I assume where the trailer is bolted together (there are two on each side). The ants were getting inside at the very end of the rubber strip. There must be an extremely tiny hole at the end even though the rubber is compressed. Once the ants are inside where the tanks are they have easy access to the inside of the trailer because of the large hole cut for plumbing and the tank heater vent. You cannot seal this hole, so you must make sure the tank compartment is completely sealed.
Ants are amazing...
Derek
Derek Johnson is offline   Reply With Quote
Old 04-19-2025, 06:29 PM   #2
Trailer: Scamp 13’
Wisconsin
That was some impressive detective work on your part.
sunnyone is offline   Reply With Quote
Old 04-19-2025, 08:19 PM   #3
We once had ants crawl up the drain tube for the OEM icebox, which we use for dry storage. They attacked a beautiful strawberry pie we had in there and nothing else. The pie was a total loss, and it took a while to help the last of 'em find the exit. I plugged the drain, since we never use ice in it.
We'd been to the same location before, and we never had trouble until we gave them a reason.
Old 04-20-2025, 10:52 AM   #4
jerrybob's Avatar
Trailer: casita
Spread some Diatomaceous Earth (DE) around ground contact points. We camped at a campground in So Calif years ago with an ant problem. The campground host came through every few days and asked if we needed more.....most campers did it....it solved the ant problem.
jerrybob is offline   Reply With Quote
Old 04-20-2025, 11:08 AM   #5
Thanks. I'll pick up a bag to have on hand.
Old 04-26-2025, 10:14 AM   #6
Trailer: scamp
Indiana
Ants are amazing...
Derek
Even trying to seal something rodent proof is a challenge. Not sure bug proof is possible.
I have had to deal with ants nests in NEMA enclosures which are metal or plastic boxes that are supposed to be waterproof used for outdoor electronics.
So a total seal might not be possible and could be dangerous. Don't forget that we breath O2 and put out H2O and CO2. Seal it to well and you might suffocate yourself. Sounds impossible, but there have been cases where several guys were operating a radio contest in a small basement and got enough of an imbalance to make themselves sick over a weekend. And that was not even totally sealed.
computerspook is offline   Reply With Quote
Old 04-26-2025, 10:45 AM   #7
Mike Magee's Avatar
Trailer: 2012 Escape 19
I'm pretty sure I emit some methane, too! If only it deterred ants...
Old 04-26-2025, 12:46 PM   #8
Trailer: scamp
Indiana
I am sure this was a bit of a problem too.
Actually Mercaptan is what would deter things including ants, but that would be unlikely. We would never detect the methane.
Old 04-26-2025, 03:28 PM   #9
...a total seal might not be possible and could be dangerous. Don't forget that we breath O2 and put out H2O and CO2. Seal it to well and you might suffocate yourself. Sounds impossible, but there have been cases where several guys were operating a radio contest in a small basement and got enough of an imbalance to make themselves sick over a weekend. And that was not even totally sealed.
We're really just talking about one section of the trailer, the bottom. That's one area I think it's worth some trouble to seal as completely as possible.
As to ventilation and air quality, most people have a window and/or roof vent open at night when everyone's inside with the door closed. CO2 aside, with two adults and two teens in a 13' Scamp, the air quality would get pretty rank otherwise.
Old 04-26-2025, 05:19 PM   #10
We've used Borax or Ajax cleanser around our tires, leveling blocks, etc and that helps keep ants out. Our problem we had was the ants were coming out of a tree we were parked under and were jumping or falling onto the trailer and coming in through the screens. We had to spray insecticide around the windows but they still fell onto the screens and got in. This was in Tennessee.
Old 04-26-2025, 06:32 PM   #11
FL
Got in the practice of spraying a barrier around the drip line of our camper as part of setting up. Gasses off quick with no residule smell. Even do it on pad sites ,but especially dirt sites. The Caribbean Crazy ants are the worst, but a mound of fire ants can ruin anyone's day. And now to the classic 1954 "Naked Jungle" staring Charles Hestin v/s Army Ants. https://youtu.be/aCva4u4hS0I?si=-MssaQq--JvEVomd
mosquito13 is offline   Reply With Quote
Old 04-27-2025, 10:11 AM   #12
jerrybob's Avatar
Trailer: casita
I've seen this happen. We knew we had a problem when we returned to our campsite and saw hundreds of discarded little parachutes on the ground around our trailer.....those ants are clever! LOL!
Old 04-27-2025, 06:26 PM   #13
I had a problem with wasps setting up housekeeping in my frame tubing until I plugged ends with plywood blocks and silicone.
barrry smithe is offline   Reply With Quote
What really works to keep ants OUT of yer TT? Fred762 General Chat 17 05-14-2018 07:53 AM
ANTS IN RV!! Just bought an old rv, HELP! MobileArtDept Problem Solving | Owners Helping Owners 7 06-17-2015 04:56 PM
How do you get rid of ANTS? Linda R002 General Chat 19 10-16-2007 10:25 PM
Ants in your trailer? Legacy Posts Problem Solving | Owners Helping Owners 2 08-19-2003 08:00 PM
» Trailer Showcase
Carmela
rvaldez
Siesta
DannyH
