Anyone know the exact size of Bigfoot 17, old model like 1986 - Fiberglass RV
Old 12-22-2023, 09:13 PM   #1
Trailer: BOLER
Post Anyone know the exact size of Bigfoot 17, old model like 1986
Currently I own a 13 ft boler, which can be perfectly fitted in my garage after removing the top hatch cover, now I plan to change to a bigfoot 17,the old model such as 1986 or similar. The length is not problem, garage is long enough, but no idea about its height and width. , but have no idea how bigger it is comparing with 13 ft boler. Thanks in advance!!
wj23176 is offline   Reply With Quote
Old 12-23-2023, 07:50 AM   #2
Just like you'll never find any two bolers that are the same height (to the inch), you'll find the same with any trailer of any brand of a 1986 vintage. The only way you're absolutely going to know is to measure THE trailer you're interested in. Then what are you going to do, when it's time to change the axle?
Good luck
Old 12-23-2023, 10:20 AM   #3
The 17' Bigfoot is more than a foot wider and quite a bit taller than a 13' Boler. If your Boler just fits, the Bigfoot doesn't stand a chance. Not only is the suspension higher, but the cabin is taller inside for more headroom.
You're up against basic geometry. As length increases, it is necessary to raise the suspension to keep the tongue and bumper out of the dirt due to longer overhangs. The earliest 13' Scamps were right at 7' tall, same as Bolers. But when they created the 16' model, they raised the axle height 3-4".
Unlike Boler and Scamp, Bigfoot rides on a leaf-spring suspension. Many people "flip" the axle to increase clearance, but that also raises the height. So if any owners provide some actual dimensions, make sure you clarify whether the suspension is stock or modified.
Old 12-24-2023, 03:28 PM   #4
Trailer: 2013Escape 21
Iowa
Doors
A nine foot wide door and a header height of 10
Feet and you’re golden. 12 foot sidewalls and a ten foot overhead door is preferred.
Iowa Dave
Iowa Dave is offline   Reply With Quote
bigfoot
Does anyone know what Bigfoot Model this is..? BigFoot Pat General Chat 4 10-02-2023 05:56 PM
Need rear sliding window channel with flocking - need exact part number idiotsniff Problem Solving | Owners Helping Owners 16 06-27-2013 08:45 PM
Exact bed length and width of 13' Scamp? David Tighe General Chat 11 06-25-2013 10:32 PM
exact window cutout sizes Boler B-1700 D Kovetsky Care and Feeding of Molded Fiberglass Trailers 2 07-15-2011 05:11 PM
Anyone know what model/ brand this might be? SGraves Hi, I am.... 13 04-11-2011 06:09 PM
