ATWOOD 36681 dual detector purchase? - Fiberglass RV
Old 03-09-2020, 11:40 PM   #1
AC0GV's Avatar
Wisconsin
Mine RV uses an ATWOOD 36681 dual CO/LP detector. Walmart price $152, E-TRAILER under $100 but I’m still looking. It is mounted in a cutout so needs to be that configuration. I've only had it for 3 years but it was 2 years old when I got it new from Scamp. Any one know who makes it, or a cheaper place to buy it? (yes I know the light's on, that happened the first summer that I had it, I cleaned it and it tested OK after.)
THANKS
AC0GV is offline   Reply With Quote
Old 03-09-2020, 11:46 PM   #2
Glenn Baglo's Avatar
Not certain about the unit you have, but I bought a propane gas detector and noted that the date on the back of it indicated it was made six months earlier. I questioned the retailer and she phoned the distributor who contacted the manufacturer.
The manufacturer said the clock starts running from the date it is connected to an electrical source.
So you're probably good for a couple more years than you think. Also, mine indicates with a chirp and LED that it is nearing end of life.
I'd check the installation manual that came with your unit, or look it up online if you didn't get the manual.
I'd also vacuum the face plate or wipe it with a damp cloth as indicated in the manual.
Old 03-10-2020, 04:24 AM   #3
AC0GV's Avatar
Wisconsin
LP Detector life
On line says that they last 5,7,and 10 years, The spec sheet for mine says "Lasts up to 7 years from the time you first turn the unit on". So I'm going to save my money. I also found that the current rating is listed as 0.01 amp or as much as 0.075 amp.
Old 03-10-2020, 01:34 PM   #4
Jon in AZ's Avatar
“Up to” is the operative phrase. Our household detectors typically begin to exhibit erratic behavior- random false alarms- well before the calendar or warning beeps signal end-of-life.
IIRC, the manual for mine says extreme temperatures (common in stored RVs) shorten life.
Old 03-11-2020, 06:12 AM   #5
Minnesota
I wonder if the "Clock" stops when you disconnect the power?
Rick In Mn is offline   Reply With Quote
Old 03-13-2020, 08:39 PM   #6
Originally Posted by Rick In Mn View Post
I wonder if the "
No once activated it is active and disconnecting it doesn't change the age
our use factors.
Old 03-14-2020, 07:20 AM   #7
our use factors.
This has come up before and I asked this question at that time but never got an answer... so perhaps you can explain:
How does a propane alarm detect that it is at end-of-life? What is the specific technology and how does it function when, for an extended time, there is no power (and no internal back-up battery)?
Apparently the propane alarms used in RV's use an Electrocatalytic detector which is described in detail starting on page 14 of this document.
But I see nothing about how the sensor ages out or how the device detects the age or effectiveness of the sensor or device. It does appear that there is not an internal clock and there is certainly not a GPS receiver to get the date and time. So... "how do it know?"
Electrical ?? regarding Atwood LP CO Detector install Stretcher Electrical | Charging, Systems, Solar and Generators 7 06-16-2014 11:26 AM
CO Detector On Sale at Ace Hardware Patrick M. Problem Solving | Owners Helping Owners 15 01-13-2007 07:37 PM
Propane detector Chris Z Care and Feeding of Molded Fiberglass Trailers 13 02-24-2006 10:23 PM
Propane detector and Carbon Monoxide detector. Yves Pelchat Problem Solving | Owners Helping Owners 6 02-05-2006 10:28 PM
LP Gas Leak Detector? Alex Atkinson Problem Solving | Owners Helping Owners 4 11-20-2005 10:25 PM
