BBQ (high heat) paint for stabilizing jacks on Scamp - Fiberglass RV
Old 02-02-2020, 10:49 AM   #1
Trailer: 1992 Scamp 13'
Right now I have an electrical issue with my 1992 Scamp, so I'm turning my attention to my 2008 Deluxe which is in MUCH better operating condition and it takes my mind off the other trailer.
There's really not much to do on the 2008, so I'm looking around for projects for it and I noticed that the stabilizing jacks need a refresh.
I have a spray can of BBQ paint in flat black. Has anyone used this type of paint to refresh the jacks? I'll show a photo of one of the jacks below.
What would you suggest?
Thank you.
1992 Scamp 13' Standard, 2017 Casita 17' ID,
2008 Scamp 16' Deluxe Layout 4
lisantica is offline   Reply With Quote
Old 02-02-2020, 07:31 PM   #2
Thank you.
Clean and degrease, do a bit of sanding or wire brushing to remove loose paint. Don't coat it too heavily or it won't slide in and out the way it should.
Pay attention to the ambient temperature outside so that you are not trying to paint when it is too cold. Pay attention to how long it needs to cure to be sure it has enough time to cure before it gets dark and also before the dew point sets in. Getting good results is about prep work and paying attention to the instructions for recommendations of what is needed for temperature and cure times.
I don't see any problem with using flat paint other than the dirt does not wash off as easily. Gloss paint has its advantages for letting water run off the surface more quickly. There is less surface tension on gloss paint versus flat paint. My preference is for gloss paint.
k corbin is online now   Reply With Quote
Old 02-02-2020, 09:55 PM   #3
Thank you for the tips, I'll go to the hardware store and see what they have.
Old 02-03-2020, 04:03 AM   #4
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
If they are very rusty, I would go to Harbor Fright and get a can of Iron Armor Rust Converter, one of the few excellent products they sell. I would spray the jacks per the can’s instructions and let it cure prior to painting.
Old 02-03-2020, 09:32 AM   #5
Thank you CPW, I didn't know about that product.
Old 02-03-2020, 10:51 AM   #6
Trailer: 1971 Hunter compact Jr, 1979 Terry 19', 2003 Scamp 16'
There are several brands of rust converter on the market. Those that I have used have all worked well. Harbor freight has had the best price. They convert the rust to what was call gun black at one time so most are in black paint as a carrier otherwise they end up splotchy. Read the instructions. It only works on rust and it does not stop new rust any better than normal so if you sand to thoroughly it is a waist. An excellent product.
Terry in Fowler is offline   Reply With Quote
Old 02-03-2020, 10:59 AM   #7
+10 I always start with rust converter, it turns black. Then top off with black paint of your choice. Myself I am brushing it on. More efficient paint wise, no overspray.
I restore vintage steel bikes, I have a rust regiment I go through including chemical treatment (retired Chemical Engineer). Then I use the rust converter. In this case I would just go with rust converter.
Old 02-03-2020, 03:31 PM   #8
Thank you all for the confirmation on the rust converter.
paint, scamp
How to replace extender jacks in Scamp with scissor jacks Nanette Del Monaco Modifications, Alterations and Updates 23 10-27-2018 12:23 PM
high efficiency propane heat DavidSo Modifications, Alterations and Updates 20 10-17-2016 02:10 PM
rear stabilizing jacks Mo22 Problem Solving | Owners Helping Owners 23 05-18-2007 03:16 PM
Stabilizing Jacks... Kurt in BC Problem Solving | Owners Helping Owners 3 07-20-2006 11:33 AM
Stabilizing Jacks Kevin W Care and Feeding of Molded Fiberglass Trailers 14 06-12-2006 10:56 PM
