01-15-2022, 11:29 AM
Trailer: 1989 Lil Bigfoot
CA
Biting the bullet… to get back on the road.
It’s time to get cracking. My poor Lil B has been parked for around five years.
She had a new axle with brakes, and new tires with around 3k miles on them. But, 5 years old.
I just ordered a tow bar assembly for the Volvo XC60, which will be installed 2/2/22.
After that, I will tow the trailer in (carefully) to get new tires. (I know there is much discussion here about tires… will read up, but any recommendations still appreciated.)
Then I plan to spend the spring doing various repairs and other upgrades.
Battery? Completely dead. Need one.
One solar panel (35watt I think), not much but will charge cell phone if needed.
Windows need work. Plastic slider tracks need cleaning.
Curtains, launder. Maybe replace.
Curtain rods: my copper tubing, which “swoops” around the curvey corners of the trailer were fun but not durable.
They droop on the road, so will be looking for a different strategy.
The back overhead cabinet sags on one side.
Fixing this may be beyond my skillset. Any advice or encouragement is appreciated.
The backsplash has also shambled down and needs a complete redo. Condition too shameful to photograph and share.
There is so much more to do! Oh, and the propane tank is old and I don’t think they will fill it. But I do have a full tank on the BBQ, so can probably use that. (I haven’t barbecued in 5 years either. Losing a spouse really hampers motivation.)
As you might guess, I’m working alone and could use a few “attagirls”. Any thoughts or discussions about any of this sincerely appreciated.
Best,
EllPea in CA
01-15-2022, 11:49 AM
Sounds like you have a good plan for with ahead. It will look great.
I go wonder about the tires though, with little mileage and only 5 years old why not wait a year at least? I usually go 7 years depending on tire condition.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
01-15-2022, 12:13 PM
CA
Jim, they have been sitting in the sun on concrete. I hate to risk a blowout, especially with a single axle where the fiberglass damage could be pretty catastrophic 😳!
Best,
EllPea in CA
01-15-2022, 12:26 PM
Glad to have you back in the "active" category. I have missed your regular participation. Grief is a long journey. You got this!
Agree with Jim about the tires. Unless they are weather-cracked, I'll bet you can get another season or two out of them. (EDIT- and I now see you've already addressed that...)
One easy strategy for the propane tank is take it to one of the many places that does exchanges and swap it for a filled newer tank. Maybe Home Depot when they're not too busy and you can talk the employee into checking a few in their inventory for expiration date so you can get the newest.
Not sure about the curtain rods. I like the idea of wraparound rods where the curtain can completely clear the windows when views are desired. But I have yet to see the perfect solution.
Lil Bigfoot has wooden cabinets where my Scamp has fiberglass. Thinking you might need to cut out a section of the shell lining inside the cabinet and epoxy a wood block to the shell to give a place to attach the sagging section.
Best wishes!
01-15-2022, 02:21 PM
CA
Best wishes!
Thanks Jon! So now do you agree with Jim about tires? Or me?🧐
Best,
EllPea in CA
01-15-2022, 03:13 PM
Originally Posted by EllPea in CA
Jim, they have been sitting in the sun on concrete. I hate to risk a blowout, especially with a single axle where the fiberglass damage could be pretty catastrophic  !
All my trailers pretty much sit in the sun. Having 2 to 3 trailers on the go at a time kept me thinking of budget asking with safety. You could do a good check of the surface, but it is more the deterioration that happens through the entire walls that is a factor than just a bit of the surface.
Your money, your call.
I bought a 1994 24' fifth wheel in 2016 that had only been towed 150 km to a rec site and parked with covers on the wheels. The tires looked brand new with little hairs from moulding still on them. I did take this 150 km right to the shop for new tires. Only after they looked at the date stamp on them did they believe me how old they were.
2017 Escape 5.0 TA
01-15-2022, 05:09 PM
I did not change my initial response after reading your intervening post so that's a fair question...
On reflection I'll stand by what I said: if there's no significant UV cracking of the sidewalls, you should be good. You could have a trusted tire dealer or mechanic take a closer look. But in the end, tires are not that expensive, and if it will remove a source of anxiety, do as you have planned.
'Go not to the Elves for counsel for they will answer both no and yes.' (JRR Tolkien)
01-15-2022, 05:16 PM
The best tire available is only around $60, maybe good peace of mind?
Carlisle HD load range "C"
01-15-2022, 06:21 PM
CA
Jon, you obviously spoke (wrote) a mouthful there!
(Says the English major who also worked with a Tolkien scholar!)
Best,
EllPea in CA
01-15-2022, 06:25 PM
CA
Floyd, it is peace of mind I seek. Getting the appropriate tow bar represents some $$, and to cheap out on tires… when I may be traveling alone some of the time? Seems unreasonably risky!
Thank you for the suggestion. Is this a trailer tire?
Best,
EllPea in CA
01-15-2022, 06:32 PM
CA
Jim, I think I would be less worried if these had covers over the last 5 years. They should have, but unfortunately we had other things happening in the family and the Lil B was way down on the list of priorities. Congratulations on safely arriving at the shop!
Best,
EllPea in CA
01-15-2022, 06:50 PM
…Thank you for the suggestion. Is this a trailer tire?
It is. It’s what I have on mine as well, and I’ll second the recommendation.
Do you have 13” or 14” wheels on your trailer?
01-16-2022, 09:34 AM
Trailer: Casita SD
If you use 14" or larger tires you also have the option of Goodyear Endurance which is MUSA, if that matters.
01-16-2022, 10:06 AM
Yes it is ST 175/80R 13...
This is the only tire I put on Eggy-Sue (the pull-it surprize)
https://www.discounttire.com/buy-tir...adial-trail-hd
01-16-2022, 10:33 AM
CA
Shelby, I do like the look of larger tires, but the new axle has already lifted the trailer higher than I like. I’m sure there is some other advantage to tires larger than the stock size?
Best,
EllPea in CA
01-16-2022, 10:42 AM
Only that you have a few more tire choices, like the Goodyear.
In your case, there is no compelling reason to up-size. 13" tires have plenty of weight capacity, they're a bit cheaper, a bit lighter to handle, and neither treadwear nor bearing life will be appreciably degraded by the slightly faster rotation.
When you get into the 15-16' class, then 14" or 15" wheels begin to make a lot more sense. 15" is the most common size for trailer tires, so that's where you'll find the best in-stock inventory if you have to replace a tire on the road in some out-of-the-way location. I had to order my 13" Carlisles and it took a couple of days to get them to my local tire shop.
CA
[QUOTE=floyd;833116]Yes it is ST 175/80R 13...
Floyd, that is the cutest name for your egg! Thank you for the link. It takes me directly to the local America’s Tire, which is where I get my pressure checked, and was also hubby’s choice. Their website indicates Two tires would be available by Tuesday, so yay! (I have been worried about supply with so many transportation problems elsewhere.)
John, I am pretty sure they are 13”. But obviously will check before ordering. What do you have?
Best,
EllPea in CA
01-16-2022, 10:46 AM
CA
Jon, thanks. I’ll stick with 13” I think. I do have some questions below about the process….
Best,
EllPea in CA
01-16-2022, 10:47 AM
Trailer: Casita SD
I just didn't know what size you had, not recommending any change. I have those Carlisles in 15" on my trailer and they have been perfectly satisfactory.
01-16-2022, 10:51 AM
CA
About the tire PROCESS
So, when we get new tires, how do we do that? I suspect the hubby took the wheels off himself and took them in. (He also replaced and balanced his motorcycle tires himself… and built the gadget to check the balance before putting them back on)
So I take the trailer in… should it stay hitched to my TV? Can they handle this in the lot, or do they want it in one of their bays? I do know they may need reminding about WHERE the jack should and should not go.
Best,
EllPea in CA
