Boler kitchen backsplash - Fiberglass RV
Old 03-08-2017, 09:42 PM   #1
Trailer: Trillium 1979 13ft.
I have seen numerous photos of various backsplashes and was wondering how they are attached to the foam wall material. Any suggestions from those who have done this mod?
Butsky is offline   Reply With Quote
Old 03-09-2017, 10:24 AM   #2
I like the shinning mirror back-splash. Don't the material.
HawkBoler72 is offline   Reply With Quote
Old 03-09-2017, 01:52 PM   #3
Borden's Avatar
Name: Borden and Carole
Ours is on with rivets into acorn nuts. Arbite
Our postage stamp in heaven.
Old 03-09-2017, 01:54 PM   #4
Borden's Avatar
Rivets from outside hold splash to foam wall, we are going to change ours to new arbrite topping.
Old 03-09-2017, 08:51 PM   #5
Backsplash
Hmm... A bit reluctant to do any she'll drilling/riveting unless no other way. Perhaps somehow gluing piece of arbour item or sheet plastic to Ensolite, then peel-and-stick backsplash tiles from Home Depot. Running through options at this point...
Old 03-09-2017, 09:36 PM   #6
I used contact cement
Mollie is offline   Reply With Quote
Old 03-10-2017, 10:56 AM   #7
Trailer: Scamp - "The Haunted Mansion" (13') and TBD (16')
Our trailer was a total rebuild, so we were down to the fiberglass shell. Heavy duty construction adhesive was used to attach the backsplash to the wall directly. Once on, we trimmed it on the top and bottom to hold it in place, and the interior ring of the window also helped.
Sohkraites is offline   Reply With Quote
Old 03-10-2017, 02:44 PM   #8
I used 1" X 1" glass tile. I attached it to the ensolite with a dab of construction adhesive on each tile. The ensolite was cleaned well with Tilex. Then instead of grout, I used almond coloured silicone. It stayed flexible and after many a washboard roads is still attached.
TimR is offline   Reply With Quote
Old 03-10-2017, 02:49 PM   #9
Johnny M's Avatar
Deep South
If you were to wrap this around say the front corner to the right of the kitchenette how would you cut it?
Old 03-10-2017, 03:22 PM   #10
I haven't done it (since we don't cook inside right now), so my opinion is of limited value. If I did, I would use a single sheet- stainless steel, pressed tin, or molded plastic, depending on the look I was going for. I would rivet it in place using the existing holes for the top of the lower cabinet and the bottom of the upper cabinet- just slip it between the cabinets and the shell covering and use slightly longer rivets. No new holes and no adhesive.
For myself, I'm not a fan of tiles- too much movin' and shakin' in a trailer.
I saved this photo for inspiration, taken from a trailer that sold a while back. It uses a stainless steel panel. It looks like the window was removed and reinstalled so the backsplash is under the trim ring, but I'm not 100% sure. It also looks like they bent it to cover the countertop as well, probably since they changed the sink to a different shape. Don't think I would go that far, but it sure looks nice!
Old 03-10-2017, 04:03 PM   #11
Backsplash
Thinking of gluing the plastic panel on foam lining and attaching those peel-and-stick fake tiles that my wife picked up. That SHOULD work! Lol!
Old 03-10-2017, 05:23 PM   #12
Wrapping around that front corner is a tough one since it's a compound curve...The tiles we used worked well on the side, but we stopped out when it started to get out of square.
Old 03-10-2017, 06:26 PM   #13
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Ours is not pretty but functional. We have rat fur I wanted to cover. It is one piece, cut to fit that bends. I used Velcro to stick it in place. This can be removed. Our Scamp also has an area that we could kind of stick the end of the backsplash into the space between counter and wall. I did not think of this when I used Velcro, found out about that method later.
Nancy
Nancy is offline   Reply With Quote
Old 04-14-2017, 10:18 PM   #14
Jan Dyke's Avatar
Trailer: boler
I was thinking of doing something on the boler i just bought. clean the wall, even on peel and stick I would use contact cement on both surfaces. For grout there is pre mixed, it doesn't seem to set rock hard and is easy to use. Home Depot carries it
Jan
Jan Dyke is offline   Reply With Quote
Old 04-15-2017, 11:16 AM   #15
Trailer: 13' Boler
My trailer had a piece of arborite already in place that had been attached with sort of an aluminum trim that is bolted through the fiberglass. I didn't like the color so I've put peel and stick floor tile over it.
It was a bit of a pain as absolutely nothing is square and the tile was more like "peel and not stick". But nothing a little contact cement wouldn't fix.
firiel77 is offline   Reply With Quote
boler
Formica backsplash over Scamp rat fur? peterh Problem Solving | Owners Helping Owners 53 10-05-2017 09:38 PM
Kitchen or no kitchen? AJCmedia Modifications, Alterations and Updates 44 04-02-2016 03:25 PM
New kitchen/backsplash/cabinets Scamp Camping Modifications, Alterations and Updates 12 07-19-2012 11:36 AM
Kitchen & Backsplash kconley Modifications, Alterations and Updates 10 08-24-2010 02:16 PM
Finding a product for a backsplash Gigi Problem Solving | Owners Helping Owners 20 04-30-2006 08:34 AM
