06-08-2015, 10:13 PM
Trailer: 13 ft. Scamp
cabinet latches?
Hi everyone! I finally got my '84 Scamp redone and on the road for the first time. When I opened the door at my stop, I realized I have more work to do on the cabinets. Needless to say, things were everywhere! The hinges on the closet door actually lost the screws and the whole door came off. What do you use to help keep cabinets closed tightly? I am considering toddler latches of some kind but would like your input.
Thanks in advance!
06-08-2015, 10:37 PM
Things inside the cabinets banging against the door cause the problems. Stop the stuff from banging against the doors and no more problems. I have had my Scamp for 10 Years with close to 100,000 miles on it, some it over gravel washboard. I have plastic containers in the overhead cabinets to contain small items. Stuff in tight in the closet so it doesn't bang around. The refrigerator has refrigerator bars to keep stuff from banging into the door.
That slowing down has prevented stuff from cabinets from ending up on the floor and there's been zero damage to the doors or hardware.
06-09-2015, 03:00 AM
Trailer: Escape 5.0 TA
W. Mass
Went to these, so far so good.
Bob & Deb
06-09-2015, 09:52 AM
Trailer: 2011 Scamp 13'
Yes, this is an issue with both old and new trailers. It's frustrating that stronger, more efficient locks don't come with the new trailers. I'm still looking for the solution I want to install with minimum drilling.
Take a look at this thread http://www.fiberglassrv.com/forums/f...hes-56105.html for some solutions others have come up with. You can do your own search on this forum. Simply go to the "Search" bar, drop down to the "Google Search" and enter the words cabinet latch. There you will find other's solutions/suggestions.
When we traveled in New Zealand in a "caravan" camper, similar to a VW bus, the cabinets had the push-in (lock) pull-out (unlock) knobs and they worked great. As for me, I would rather have a retro look to my cabinets or a hidden latch system.
The Gleeful Glamper
Gilda (Jill-da)
06-09-2015, 11:42 AM
Thank you all! You have given me some nice options!
06-09-2015, 02:59 PM
I had an issue with the screws loosening and doors falling off with my Scamp. Screws don't hold well forever in partial board. I made new doors of wood, then reused the original catches, I've had no problems.
2021 Nissan Pro 4X. 2020 Scamp 19’ Deluxe.
06-14-2015, 04:13 PM
Here's my solution to the 3 cabinet doors over the kitchen in my 13 Scamp.
The is felt on the back side so as not to scratch the doors.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
06-14-2015, 06:03 PM
06-14-2015, 06:59 PM
GREAT idea Joy for those that have knob pulls.
06-14-2015, 07:43 PM
Name: Steve and Janna
Trailer: '02 Scamp 13
Found them at Home Depot online. I confess to splurging a bit - but really like the look. Have yet to have one pop open on its own. Put them everywhere except for a couple magnet latched doors that so far have not opened up.
Deb - it looks like you are discovering there are a range of options for keeping things where they belong while rolling down the road. I think the bottom line is the sorts of roads you like to travel. Rough & bumpy calls for more strenuous solutions, such as Joy's.
06-15-2015, 11:39 PM
Thanks again everyone! I love all of the ideas. I have found that, as Dennis said, the screws don't hold in the particle board. I may have to replace doors eventually. My most recent "chick fix" was to drill all the way through the fiberglass to use a bolt through the hinges on the closet door. Still won't fix the problem of screws in particle board, but it is a start. Going on a test run this weekend. Stay tuned. I'll let you know how they worked.
06-16-2015, 01:47 AM
Trial and error is how it works
06-16-2015, 06:19 AM
I have a bungy cord covered in bunting flag that I use. A little hole drilled in either end to hook the bungy to. The bungy system was in place when I bought the trailer last year. I covered it in bunting flags to match my new decor.
Not all who wander are lost ~ JRR Tolkien
Looking forward to many adventures in my '76 Boler
06-16-2015, 06:32 AM
Trailer: 76 Trillium 1300
Waterloo, Ontario
I am just curious, as I have not finished my Trillium yet to try them out, but are most people using sprung cabinet hinges that hold tension on the cabinet door in the closed position? They even help close the door. Like these that I was going to get from Leevalley?
Standard Steel Door Hinges - Lee Valley Tools
Do I need some sort of secondary 'door latching' system as these are not enough?
stefan
06-16-2015, 08:29 AM
Stefan, the problem is that the screws that come with the hinges must be cut down for the size of the door or they will go through to the other side. You will still need something on the other side of the door to keep it closed. I am using bungy cord for some. The closet door is the biggest issue. I haven't found "hookable" spots for the cord.
06-16-2015, 09:37 AM
As an alternative to building new doors, I have drilled out the screw holes and glued pieces of dowell that fit the diameter of the drilled holes, then use the original screws into the dowell. This is not ideal, because screws into the end grain of wood is only marginally better than screws into partial board. I purchase my dowells from a local wood supplier, so they are of higher quality and screws hold better than they do in dowells purchased from a craft store. A better solution is to buy a plug cutter. (I bought mine from Lee Valley). Then you can make your "dowells" with cross grain so the screws hold better. You have to decide if the more permanent solution is worth the additional expense.
06-16-2015, 10:02 AM
Waterloo, Ontario
If I get a chance I'll try to hot glue a rare earth magnet to the top and bottom of my old closet door and then temporarily tape a piece of steel to the inside of the cabinet (both of these things on the side away from the hinges) and see how that holds. Actually could maybe do it in a few spots on the way down and see if that, combined with the spring hinges, feels like it would have enough strength.
It might be a while as I am just starting to primer all my cabinets to do a color change.
Maybe you could tape some on and see if it works/helps. Know any one with some old computer hard drives. I love the magnets in there.
As far as the screws are concerned, I was thinking rivets. I usually put a small dab of epoxy in the hole and then use an appropriate sized aluminum rivet. Have never had those come loose on other projects. Never tried it on a trailer though.
stefan
06-16-2015, 12:46 PM
cabinet latches?
It's possible the problem is not the cabinets, but the axle on the trailer. The rubber in old torsion axles can become hardened and lose its spring. One test is to jack up the trailer on one side (on the frame near the wheel). Watch to see if the wheel drops as the frame rises. Little or no movement means a shot axle and a very rough ride.
I have never had anything come out of our cabinets (standard Scamp hardware). We installed stacking bins in the large closet:
and small crates in the overhead cabinets:
Doors remain closed and everything stays in place just fine.
06-16-2015, 01:12 PM
Waterloo, Ontario
Everything stays in place just fine.
Good to hear. I would assume that the standard Scamp hardware has springs on the hinges? I know the original Trillium hardware in 1977 did not. Love the bins. Was thinking of something similar, when I get that far. Now I have primed white cabinets instead of yellow (colonial white).
06-16-2015, 01:18 PM
cabinet latches?
Nope. Scamp uses the cheapest hardware store hinges and friction roller latches. Very basic. When I first got my trailer (used) three years ago, the latch on the closet door was misaligned (from the factory, I presume) and wouldn't stay closed. I rotated the door 180 degrees and reinstalled the hardware and haven't had any trouble since.
BTW- the bins in the closet are from Big Lots. Perfect size, and they latch together for stability. Only $3.50 each.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Cabinet Door Latches
CliveAlive |
8 |
01-25-2010 08:20 PM |
Trillium Cabinet Latches
jimliston |
7 |
01-21-2009 11:38 PM |
Cabinet door latches
Ian R |
7 |
05-23-2007 10:35 AM |
Casita Cabinet Latches
Legacy Posts |
1 |
08-06-2003 06:15 PM |
cabinet latches
Legacy Posts |
0 |
06-01-2003 11:37 PM |
