Casita TV Cable question - Fiberglass RV
Old 05-11-2020, 11:59 AM   #1
jgilliam1955's Avatar
Trailer: Casita Liberty
Virginia
I have a 2019 Casita & noticed a black TV Cable running from the Antenna Box through the cabinets to the kitchen/bathroom wall behind the carpet. What is there?
Been with my sweetheart since 1969
Burned by Snoozy, Now a Casita owner
We enjoy Whole Plant Base food
If I won the award for laziness, I would send somebody to pick it up for me.
jgilliam1955 is offline   Reply With Quote
Old 05-11-2020, 12:07 PM   #2
jon carpenter's Avatar
Trailer: 2013 Casita 17' SD
Illinois
The antenna is glued to the fiberglass before the carpet is glued up. It is somewhere between the bathroom door and the ceiling fan. At least that is what I was told.
jon carpenter is offline   Reply With Quote
Old 05-11-2020, 04:49 PM   #3
Virginia
Thanks for the reply.
Old 05-12-2020, 11:20 AM   #4
Idaho
I received similar information from Casita on my 2019 SD17. When I checked out the antenna, I was disappointed. Don't expect much from the antenna. It is what I would consider a very cheap antenna. I even told Casita that I felt they failed their quality build and name with this product.
In my attempt to research the antenna, I received the following message from my sales representative at Casita.
Bob,
The only information I can find for the antenna is part number AN350. Unknown manufacturer. We purchase it through Kingston Distribution, LLC. I’ve found the same part number on other websites but cannot find a manufacturer. As you know, we no longer purchase it through ASA Electronics.
Carla
Using Google search, I was able to find a 2-page PDF file online that covered the installation of the antenna. The manufacturer is no longer in business. I pretty much received a run-around when calling trying to get specifications on the antenna from Kingston. Google AN350.
The PDF is strictly installation instructions with one very simple graphic of a SUV with the antenna mounted horizontally on the driver side rear window.
If you are not within about 5 to 10 miles of direct line-of-sight position with the TV station transmitter antenna, you will most likely have little or no reception from this antenna. If I had known about the antenna and its installation prior to purchase, I would not have selected this option. I consider it useless extra weight on the trailer and a waste of money.
It is possible that if you always camp in large camping facilities with the hookups, you may not have a problem. I don't know if these camping sites have TV repeater antennas or not.
Bob Penn is offline   Reply With Quote
Old 05-12-2020, 01:00 PM   #5
Virginia
I found this was a common problem, not just Casita. I purchase this. In my backyard I could not get anything. With this I got 15 channels. https://kingconnect.com/king-omnigo-...-hdtv-antenna/
casita
Cost of a fiamma awning and cable installation for 2003 casita? jenbooks Modifications, Alterations and Updates 18 05-17-2015 12:29 PM
Casita outside cable connection? iplumb Problem Solving | Owners Helping Owners 3 08-29-2013 04:39 AM
Question about how to bring the DirecTV cable into the Casita Anne3358 Modifications, Alterations and Updates 14 03-04-2012 09:39 AM
television cable Legacy Posts Modifications, Alterations and Updates 6 03-31-2003 01:32 AM
Cable Access Legacy Posts Problem Solving | Owners Helping Owners 4 12-04-2002 04:32 PM
