I know what I would do, but I've worked with fibreglass.
First off, what is causing the top to lift? If you were to put a bunch of
weight on it, or wrap it with some ratchet straps, would the top and bottom come back together? If so, do that. Then pull off the metal belly band, grind the seam from about two inches on either side, till it is paper thin where the top and bottom meet. Line up the top and bottom halves. This might involve screwing some wood across the seam to stabilize it. Apply mat style fibreglass soaked in polyester resin. Sand smooth. Bondo then
paint.
This should be done all the way around.
The devil is in the details.
