Cleaning up electrical and water ports - Fiberglass RV
Old 04-20-2017, 09:44 AM   #1
Trailer: Previously owned a Scamp 13'
New Hampshire
We've scrubbed these but the black spots are resisting. Any tips?
Doghaus is offline   Reply With Quote
Old 04-20-2017, 10:36 AM   #2
Scoboatn's Avatar
Trailer: Burro
These are pretty cheap and easy to replace. That would be best.
If you still want to try and clean mix 1 part Bleach with 1 part Mean Green and add a few squirts of Dawn. Spray on with a squirt bottle and rinse. Do a test spot to be sure it will not damage what you are working on before doing a large area.
This is the only thing I found that would clean the white soft rubber window molding on a previous camper.
Scoboatn is offline   Reply With Quote
Old 04-20-2017, 04:02 PM   #3
scrub them with barkeepers friend.
https://www.walmart.com/ip/Bar-Keepe...olish/15026756
electrical
Cleaning out water tank? barryra Care and Feeding of Molded Fiberglass Trailers 44 03-25-2015 10:55 AM
Cleaning sediment cup on water pump CampyTime Plumbing | Systems and Fixtures 4 07-13-2014 07:44 PM
Cleaning water tank Filbert V. Plumbing | Systems and Fixtures 32 02-26-2014 09:23 PM
Water tank cleaning? Filbert V. Care and Feeding of Molded Fiberglass Trailers 20 09-04-2012 05:02 PM
cleaning water tanks Dale C Care and Feeding of Molded Fiberglass Trailers 15 03-30-2009 12:11 AM
