cracks around door hinge 2017 Scamp - Page 2 - Fiberglass RV
Old 01-24-2020, 10:36 AM   #21
Berthaduniverse's Avatar
Agreed, there really should be a rubber gasket shaped to fit the hinge plate and act as a void evening contact point...
Originally Posted by Eddie Longest View Post
Back to post #1. The issue with the older hinges is the contour of the trailer does not match the contour of the hinge mounting plate. Tightening of the bolts alone can cause the gelcoat cracking because there is usually a gap between the hinge face and the trailer before tightening the bolts. I discovered this after replacing a lot of rusty hinge bolts and chasing leaks over the years. Scamp used no sealant under their hinges, at a minimum you should place butyl tape under the hinge face. To fix it right you could file the hinge face to match the trailer contour. Scamp did a good job on building up the thickness of the glass around the door frames so without further inspection I consider this type of cracking as purely a cosmetic issue but you may want to check your hinge to trailer fit and apply some type of sealant under the hinge face. Just my opinion, YMMV.
Eddie
Berthaduniverse is offline   Reply With Quote
Cracks right above door. SO0PERUGLY Care and Feeding of Molded Fiberglass Trailers 1 09-15-2019 01:29 PM
hairline cracks in FG around vent giro53 Problem Solving | Owners Helping Owners 0 07-03-2013 10:32 PM
Trillium over the door cracks, need advice Raz Problem Solving | Owners Helping Owners 14 08-26-2011 06:22 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
stress cracks over the door gregshannon Problem Solving | Owners Helping Owners 9 02-26-2007 08:48 PM
