Cracks in FG above the torpedo-belt - Fiberglass RV
Old 01-18-2021, 04:22 PM   #1
Trailer: C
Iowa
I think expanding ice pushed the torpedo-belt away from the Casita, cracking the fiber-glass. Is this worth worrying about?
whoot is offline   Reply With Quote
Old 01-18-2021, 08:09 PM   #2
Jim Bennett's Avatar
Those cracks do not look too be into the fibreglass, but just in the gelcoat.
You could clean them up scraping or sanding out the cracks. If then you can confirm they do not go into the fibreglass you could do a gelcoat repair.
I have to laugh, as a moderator I came to the thread concerned it was off topic given the reference to torpedos. None of those in our moulded fibreglass trailers.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 01-18-2021, 08:40 PM   #3
I thought I'd need to report it! Maybe the thread title should be changed to belly band...
Old 01-18-2021, 08:43 PM   #4
Trailer: C
Iowa
The cracks do not appear to be deep, so it must be the Gelcoat. I'm going to have a FG repair guy look at it soon, so I may have him fix it. Good to know it is probably not too serious, and at least the cracks are above the water line.
Old 01-18-2021, 09:50 PM   #5
Paul O.'s Avatar
We just need to expand our FGRV vernacular! Even after years of hanging out here I still think first that a TV is something with a clicker.
Paul O. is online now   Reply With Quote
Old 01-19-2021, 06:54 AM   #6
... andI I always thought a “clicker” was something you used to train dogs!
Old 01-19-2021, 08:14 AM   #7
Your young age is showing through, even here in Alberta remote controls for TVs were called clickers when they first were used. Big bulky things that made clicking noises when used.
2017 Escape 5.0 TA
Old 01-20-2021, 06:59 AM   #8
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
you guys had remote controls??? sheesh, we had to get up and walk all the way to the TV
Joe
Old 01-20-2021, 07:39 AM   #9
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
My parents had remote control of their television... they were called kids, not clickers!
Old 01-20-2021, 08:08 AM   #10
I have a remote and I still need the kids to change the program!
Old 01-23-2021, 11:42 AM   #11
Illinois
How serious is a deep crack in a fiberglass camper?
Diana Alm is offline   Reply With Quote
Old 01-24-2021, 10:03 AM   #12
Trailer: 1976 Boler Voyager 13'
TV clicker.
G'day: And I had more flicker than clicker.
JamesML is offline   Reply With Quote
Old 01-24-2021, 10:34 AM   #13
A crack that goes all the way through all layers of fiberglass is definitely a concern. It’s often caused by excessive flex in the shell, which could indicate loose rivets or even a problem with the floor or frame. Vibrations from use on rough roads are another possible cause.
They are most common at the corners of doors and windows (especially if the corner is a sharp 90-degree angle and not radiused). If you catch it when it’s small you may be able to stop it from spreading by drilling a small hole in the end of the crack (which acts like a radius to diffuse the stress). You can then seal it up and it may hold.
If it continues to spread or open up, you’ll need to do a fiberglass repair from the back side, as well as explore the cause.
Cracks above door scamp16JF Problem Solving | Owners Helping Owners 0 07-05-2020 03:50 PM
Cracks right above door. SO0PERUGLY Care and Feeding of Molded Fiberglass Trailers 1 09-15-2019 01:29 PM
trillium cracks above wheel well Reade Problem Solving | Owners Helping Owners 19 08-31-2017 08:52 PM
Snow Belt in UP of MI, driving on snow packed roads? nrthwds Care and Feeding of Molded Fiberglass Trailers 24 10-01-2015 02:16 PM
First trip under our belt ! Screaminge Problem Solving | Owners Helping Owners 6 08-12-2013 10:17 AM
