DC wiring help needed - Fiberglass RV
Old 08-14-2022, 07:34 AM   #1
Trailer: Keystone
Wisconsin
I am rewiring my DC fuse panel & need help
There is a 40a main fuse that went to a removed converter -- Can I wire this as power in from a positive bus bar off a 2 battery bank?
The negative either goes to a fuse 30a that is labeled as negative ? Or to an existing negative fuse panel bus bar ? Which one?
If the bus bar, where would I likely wire this remaining fuse (30a) that's labeled as negative?
The dc fuse panel door shows a negative white to the battery but I don't believe this is existing.
Help would he greatly appreciated, even just opinions, cheers
Agboett is offline   Reply With Quote
Old 08-15-2022, 08:13 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
if you can post a picture of what is on the converter that would be a big help, if the converter is removed, how are you charging the batteries?
Joe
DC wiring help needed Agboett Problem Solving | Owners Helping Owners 11 08-21-2022 08:48 PM
hunter help needed / walls HELP xmansurfer Problem Solving | Owners Helping Owners 4 03-13-2013 07:02 AM
Wiring help needed Stretcher Modifications, Alterations and Updates 5 10-07-2012 10:01 PM
Scamp to Subaru trailer wiring - help needed Mikeny Problem Solving | Owners Helping Owners 7 07-27-2007 05:16 AM
Brake Control Wiring Help Needed Gail Shook Problem Solving | Owners Helping Owners 8 06-07-2007 06:02 AM
