Dewinterize a Chalet Arrowhead - Fiberglass RV
RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-27-2017, 05:10 PM   #1
Trailer: Chalet
Can anyone provide step by step advice on how to dewinterize a Chalet Arrowhead. Thank you.
Alexray is offline   Reply With Quote
Old 02-27-2017, 07:49 PM   #2
Raz
Raz's Avatar
Vermont
Other than tank location my Arrowhead wasn't much different than my Trillium. I drain the antifreeze, fill the tank with water. Run the faucet until clear. Then I repeat the process, drain and fill, two more times. Then I sanitize using bleach. Fill the tank 1/2 full, add 1/2 cup of bleach and then fill full. Let sit several hours at least, over night is better. Then drain and fill 2 more times running the faucet each time. Hope that helps. Raz
Raz is online now   Reply With Quote
Old 02-28-2017, 11:01 AM   #3
Backwater Bill's Avatar
Trailer: Escape
I had the similar Chalet Alpine for 11 years. Other than checking the usual items, i.e. brakes tires, lights etc., there wasn't much to it.
I would reinstall the HW drain plug, rinse and sterilize the fresh water tank, lines and HW heater with a dilute bleach solution, lubricate the toilet seals with olive oil & re-install the batteries. Not much else that I can recall.
In the years I used the pink RV antifreeze instead of blowing the lines clear I found it took multiple rinses to get rid of the taste.
We sometimes used it in the winter for ski trips but didn't use the freshwater tank those times. If the batteries were already installed it was basically just load and go. Most of the work is taken care of in the winterizing.
Backwater Bill is offline   Reply With Quote
For Sale: 2006 Chalet XL 1930 Diane D Classified Archives 1 07-12-2016 11:19 AM
2012 Chalet XL 1937 with Dormer $15000. Soozee Classified Archives 4 11-30-2014 12:51 AM
Chalet Screen Door jonster Modifications, Alterations and Updates 15 06-15-2014 05:32 PM
For Sale: 2012 CHALET XL 1937 with Dormer CarolMarie Classified Archives 0 06-09-2012 09:50 AM
