Dometic AC on 2017 13' Scamp - Fiberglass RV
Old 10-21-2020, 07:27 AM   #1
Trailer: Scamp - Gently Used
Kentucky
Is there an air filter that needs to be changed on a Dometic AC installed on a 2017 13' Scamp w/o bathroom (if that matters)?
Been three years, and wife just asked me about it...I have no idea.
Thanks,
RogueIT
Kris & Scott | 13' Scamp Standard | 2014 Mazda CX-9 Grand Touring
RogueIT is offline   Reply With Quote
Old 10-21-2020, 08:45 AM   #2
Look for a plastic screen-like rectangular thing on the air intake, from the corners pry it out, remove the filter (its similar or the same as this), wash it, reassemble.
If you have use the A/C much it will likely be obvious what to clean.
Every so often, somewhere between 2 or 3 and 10 years, I would use A/C coil cleaner on the coil on the outside part under the shroud. The cleaner is available at many home improvement stores in spray cans.
https://youtu.be/OCL_a_HPba0
CA | 2017, May 4-8: 14th Annual 2017 FiberglassRV Rally Anne3358 Rallies, Get-togethers, Molded Meets (Archive) 21 03-27-2018 12:48 PM
ON | 2017, Sept 15-17: Niagara Wine Escape 2017 Alf S. Rallies, Get-togethers, Molded Meets (Archive) 63 10-13-2017 12:07 AM
ON | 2017, May 26-27: EggFestOntario 2017 Vivian L Rallies, Get-togethers, Molded Meets (Archive) 11 06-01-2017 05:58 AM
QC | 2017, May 26-28: Eggfest Quebec 2017 Sonya Rallies, Get-togethers, Molded Meets (Archive) 7 05-04-2017 11:32 AM
SC | 2017, Nov 2-5: Camp Snoozy 2017 charlsara Rallies, Get-togethers, Molded Meets (Archive) 1 02-21-2017 10:13 PM
