RE:
This $1600 paint job ordered by a previous owner
You cannot see it in the photo, but missing logo holes weren't filled first.
They painted right over the aluminum and black belly band trim, sealing it onto the trailer with paint. Paul later had to cut it off and spent hours getting the paint off of it.
They painted over all logos still attached. They didn't "fair" any bad areas, fill any cracks first, but went right over the top. The paint itself was rootbeer brown with gold flecks--made the trailer like an oven inside when the sun shone on it for a few hours.
It was shiny, but they didn't even paint the roof! It couldn't be seen from the ground, so...why bother? They left the original old gel coat in white up there--
with all its scrapes, flaws, gaps, etc. from the first several decades of Peanut's life.
They painted around the
windows, door, and all things protruding, leaving little paint ridges around them and not reseating the windows or vents as would normally happen after a proper paint job, leaving many tiny
leaks. Under the "eyebrow" over the door (which hade been curiously flattened rather than sticking out to provide a rain drip shield) were several large cracks, unfilled, unsealed, but painted over.
Wishing you the best with your paint job! Don't turn it over to them until YOU know it's prepped and ready!
Nobody cares like you do.
BEST
Kathleen
"K"
Below see Peanut (one shell with two nuts in it) after Paul finished his simple hot dog roller & marine enamel paint job...
Double-click on photos to get a much larger enlargement for your viewing pleasure.
