Originally Posted by Lisle
I can't figure out how to post a picture here from my computer. But the scoring on the side of my camper is very narrow (1/32"). It does go into the gel coat in a couple places, I think, because white powdery stuff fell out of the gouged line in places. What would be the right material to seal this up?
Lisle, your Casita's shell is constructed is polyester resin and chopped fiberglass. The gelcoat layer is simply pigmented (white) and thickened polyester resin.
Having owned "vintage" molded fiberglass campers for a number of years I have done many fiberglass repairs from gelcoat layer scratches and pinholes to holes in the body that I can put my hand through.
Because the cracks to your trailer are limited to the gelcoat layer, you should be able to attempt repairing. If you aren't happy with the results, just sand out and try again. Many youtube videos explain how to do gelcoat scratch and crack repairs.
First I would:
- For cracks use a small v shaped grinding bit to grind a hole into the gelcoat (but not below) at each end of the crack.
- Using the v shaped bit enlarge each crack line to accept repair material.
- Any jagged or irregular damage should be removed again with a v shaped bit.
Repair material options:
- Contact
Casita to determine if they have a matching gelcoat repair kit.
- Buy a gelcoat repair kit from Amazon or Westmarine or other supplier. Here's an example of products:
https://www.westmarine.com/gelcoat-repair
- Some people use marine tex epoxy for easy repairs to cosmetic damage.
