Hi there....sorry to see your hail damage.... but not all is lost.
What you will need is some elbow grease, some neutral base gel coat, MEKP hardener, and some pigments (ie. white, yellow, tan, depending on the colour of the gel oat on your trailer). If your trailer is a stark white, you might get away with white gelcoat, but many rv “whites” are off whites.
You will have to remove all of the gelcoat spider cracks by sanding down to fibreglass. It is always best to match a large patch rather than try to match the areas where the cracks are. Because the fibreglass is intact and the gelcoat cracked as it is harder and brittle by comparison, you do not need to worry about structural fiberglassing in your repair. Just use a sander to sand down the area to the fibreglass. The outsides of the circular area should be feathered so when you overlap gelcoat over this feathered area it will seamlessly blend in colour when you sand and buff.
Use acetone as a quick wipe to clean the area after sanding and between coats of gelcoat. You need to acetone between coats of gelcoat, but no need to sand.
Once you have built up the gelcoat(above the original and surrounding area), start sanding with 120 grit, then 180, 220, 400 wet, 600 wet, 1200 wet, 1500 wet, and lastly buffed with gelcoat wax (I use 3M brand, heavy oxidation type).
There are gelcoat repair videos on YouTube that discuss these things and more.
It seems like lots of work but I have done these repairs all over my
Boler and I would say that the bulk of the grunt work could be done in 3 hours for your repair. Make sure you take the time to mix your colour so that it matches perfectly.......this may take an hour....but time well spent. Then in small batches, mix your tinted gelcoat with hardener.
Best of luck- not to worry, your natural mishap only cost you about 5 hours.
Pete
