interior wall paint - Fiberglass RV
Old 06-09-2021, 10:51 AM   #1
Trailer: Boler 1700
interior wall paint
Hi, Im planning to paint interior wall paint on my 1977 Boler 1700.
it has stain and smell.
i am thinking just paint over that and look better like inside house.
but im not sure what kind of paint should i use for the inside wall. the wall has some fablic thing? foam? some type of insllation from factory.
any house interior latex paint i can use or automotive quolity paint use im not sure what can i use.
please any one advise me what i can use.
thank you.
Takviator is offline   Reply With Quote
Old 06-09-2021, 11:22 AM   #2
David Tilston's Avatar
thank you.
Tak, The liner on your Boler is very likely Ensolite. This is a black foam, about 1/4" thick and covered with an off white vinyl. Since it is flexable, it is not a good idea to paint it with something that will dry hard. Try to find a vinyl compatable paint.
I found a video on painting vinyl:
The paint he uses in the video:
https://www.duplicolor.com/product/v...abric-coating/
Old 06-09-2021, 04:16 PM   #3
Trailer: '78 Trillium 4500
Video How To Caulk and Paint Ensolite Seams
Tak:
I am assuming that you are talking about just painting the rubber/insulation/Ensolite, and NOT any of the fiberglass. Fiberglass would require much more preparation and care than the Ensolite to get a decent finish, and I would highly recommend boat paint designed for fiberglass if you are planning on doing tat, although I know that others have used different paint.
Painting the Ensolite is quite easy, and I have put up a video on caulking the joints and painting at
The MOST IMPORTANT PART OF PAINTING THE ENSOLITE IS PREPARATION! Make sure that you clean the Ensolite as well as you can. Use Spray 9, rubbing alcohol, degreasing cleaners etc. so the paint has a good, clean surface to stick to.
Make sure that you use a good quality primer, like Zinsser Bullseye 1-2-3, then paint over that with a good quality acrylic (water based) house paint. We like Benjamin Moore products. We used 2 coats in our Trillium. Looks great.
Go at it, and good luck!
Curt
Capn.Curt.Wiebe is offline   Reply With Quote
Old 06-09-2021, 04:18 PM   #4
All the Albertans are chiming in on this one. Where in Alberta are you located, Tak?
Old 06-10-2021, 03:03 PM   #5
Trailer: Boler 1700
Hi David,
thank you for the tip.
I think that is work for me.
i will try that thing.
thank you
Old 06-10-2021, 03:03 PM   #6
Trailer: Boler 1700
Hi Curt,
that is kind advance to me but it will works for my future reno.
thank you
Old 06-10-2021, 03:04 PM   #7
Trailer: Boler 1700
also im in Calgary
Old 06-10-2021, 03:21 PM   #8
also im in Calgary
Me too.
Capn.Curt.Wiebe is in Edmonton. I bought a furnace from him.
boler, paint
Interior Paint--Remove or Paint Over Lora Care and Feeding of Molded Fiberglass Trailers 7 12-15-2014 11:30 PM
Interior Wall Board Kim H Problem Solving | Owners Helping Owners 8 06-25-2012 05:31 PM
recommendations on new interior wall covering? LukeP Problem Solving | Owners Helping Owners 6 05-15-2011 06:36 PM
Interior wall coverings GrahamD Modifications, Alterations and Updates 2 05-05-2007 09:12 AM
Interior wall fabrics DonInChatt Modifications, Alterations and Updates 14 01-31-2007 05:36 PM
