Hi all - I was deep diving today and planning to pull the trigger on attempting a gelcoat repair vs doing a new
paint job, but after I went out and looked around my '77
Boler (I believe deluxe - but that was partially based on
paint scheme which is, turns out, not original) I noticed that there is one larger chip that reveals what looks like yellow
paint below, and the trim around the door is also a tad loose which reveals yellow also. Does that mean my
boler was painted at some point? Or is yellow what it would look like if the original gelcoat was chipped? The paint job is white with a 2 tone blue stripe below the belly band. It has the larger jalousie window in the door.
I also have to deal with a broken
porch light that I cant find a good replacement for, so whichever way I go I need to address whatever may be under there...
I dug up a ton of good stuff on dealing with old gelcoat, but if anyone has tips on the larger chips as described, or where I should start if I am working with a paintjob over the gelcoat, that would be much appreciated! I am planning on using brightside or rustoleum topside and roll and tip or the hairdryer method if I have to paint.
