Jalousie Window reno - 1974 Trillium 1300 - Fiberglass RV
Old 02-01-2020, 06:55 PM   #1
Saskatchewan
Hi,
All my windows have been pulled to paint the Trill so am also going to give the windows a refresh. Have ordered all gaskets and glazing from Vintage Trailer Gaskets.
Need to replace the torque operators while I am at it and have a few questions:
1 - where is the best place to buy replacements for the Hehr 4901/2 windows? I see them at Vintage Trailer Supply, Interstate RV Metal and Supply and Pelland Enterprises. Just wondering if people have used any of those suppliers and if you were happy with the product and service received.
2 - The original torque operators are held in place with tube rivets. I am wondering how people have attached the new torque operators...pop rivet, bolt and locknuts, tube rivets(which I can find very little information on)
Appreciate any help!
Cheers,
Murray
Kommander is offline   Reply With Quote
Old 02-02-2020, 12:35 PM   #2
I have 1978 T4500 and would never paint a FG trailer except rare occasions. Why are you painting it? Has it been painted before?
jokra is offline   Reply With Quote
Old 02-02-2020, 12:46 PM   #3
Saskatchewan
Painting it due to the leaky roof, fibreglassing the roof, covering large areas where gelcoat was worn off completely and the Maxxair installation.
I wish painting wasn't necessary but I think it was my best option given the circumstances. Here is a thread about it... http://www.fiberglassrv.com/forums/f...ard-88661.html
Cheers,
Murray
Old 02-02-2020, 08:42 PM   #4
Talk to Ian. He should be able to help you out to make sure you are buying the correct one.
https://www.campingtreasures.com/pro...ndow-operator/
TimR is offline   Reply With Quote
Old 02-02-2020, 09:26 PM   #5
Saskatchewan
Originally Posted by TimR View Post
Talk to Ian. He should be able to help you out to made sure you are buying the correct one.
Thanks Tim, will see if he can help me out.
Old 02-07-2020, 09:09 PM   #6
Trailer: Boler 1300
Ditto on Camping Treasures. Also picked mine up there. Just finished redoing the right side, now on to the left
bobdobqb is offline   Reply With Quote
Old 02-08-2020, 07:01 AM   #7
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Most local RV dealers have window operators in stock. Just bring the old one so they can provide you with the right model you need. Not very expensive, like $7 or so.
Old 06-06-2021, 12:34 PM   #8
Trailer: 1976 Trillium 1300
Murray (or anyone else) did you ever find a preferably Canadian source for the Trillium window torque operator?
Do the ones for Boler’s on Camping Treasures site fit, they look smaller?
kootenaigirl is offline   Reply With Quote
Old 06-06-2021, 01:52 PM   #9
Saskatchewan
Do the ones for Bolerís on Camping Treasures site fit, they look smaller?
Sara - here is a link to one of the operators I used from Pelland Enterprises in the US.
Expensive but they are identical to the originals.
https://www.pellandent.com/Left-Hand...-Operator-Hehr
You need left and right operators ... the pics donít match what you think is correct. I spent a lot of time with Pelland support making sure I was getting the correct number of left and right.
Iíll look for my invoice.
Murray
Old 06-08-2021, 10:02 AM   #10
David Tilston's Avatar
Last I checked, Joe Thoen at Trillium Outback has them.
Old 06-08-2021, 11:49 AM   #11
Thank you David and Murray for the info.
David I was going to PM you for your expertise on a broken fridge part. My fridge is missing both the knob that changes it from 12v, 110 and off (so the gas part will work) plus plus more importantly the shaft that it attaches too is completely sheared off.
I would like to try it on gas as it is working on electric but not sure how to do it with no shaft. Hopefully I have attached a photo
Any suggestions?
Old 06-08-2021, 12:15 PM   #12
Any suggestions?
That is a cool drawing. Could you post a link to the document that it comes from?
The switch that is broken is mostly electrical, (other than the mechanical interlock with the gas valve). As long as you can turn the gas valve on, you should be able to run the fridge on gas. Just be sure that there is no power to the heaters. Otherwise the opperation would be exactly the same as if the switch was not broken.
Old 06-08-2021, 01:27 PM   #13
Thanks for suggestions David.
I am not sure where I got the picture from, I took a screenshot and then closed the window, never to be found again
Old 06-08-2021, 02:24 PM   #14
Joe MacDonald's Avatar
if there is 1/4 inch or more of the shaft, you can probably get a coupler machined for it, alternately you could try searching "rv fridge salvage" and see if you come up with anything
Joe
Old 06-08-2021, 02:30 PM   #15
Thanks for the suggestion Joe, unfortunately there is not even a nub, it is pretty much completely flat.
I will probably keep my eye out for salvage parts.
Old 06-08-2021, 02:38 PM   #16
No problem, I had a copy of it.
Old 06-08-2021, 07:39 PM   #17
There was a pretty good salvage yard in BC that i got a few things from, I think it was Tom’s rv salvage if I remember right, there is also old farts rv parts
Old 06-08-2021, 08:06 PM   #18
Originally Posted by Joe MacDonald View Post
There was a pretty good salvage yard in BC that i got a few things from, I think it was Tomís rv salvage if I remember right, there is also old farts rv parts
BC is a big place.
Old 06-09-2021, 05:21 AM   #19
but the internet makes the whole world small..............
Joe
Old 06-09-2021, 09:34 AM   #20
Once travel restrictions are off I will check a few places as don’t want to be shipped the wrong part. Thank you.
trillium
For Sale: 1974 Trillium 1300 1300 Mooncusser NEW Fiberglass RV Classifieds | Buy, Sell, Trade 0 05-23-2019 01:37 AM
Trillium 1300 Jalousie Window Gaskets Kommander Care and Feeding of Molded Fiberglass Trailers 15 05-08-2018 05:28 AM
My 1974 Trillium 1300 Reno Mhranka Care and Feeding of Molded Fiberglass Trailers 14 12-09-2016 05:45 PM
1974 trillium reno jenniferpoitra Modifications, Alterations and Updates 24 08-12-2013 07:04 PM
Trillium 1300 Jalousie window removal krg Problem Solving | Owners Helping Owners 3 07-29-2013 09:22 PM
