Leak on black water tank. - Fiberglass RV
Old 10-26-2024, 03:45 PM   #1
Trailer: Casita 17FD
Alaska
I have a 2013 Casita 17' Freedom Deluxe. When I winterized it this month, I noticed a small leak where the ABS pipe attaches to the bottom of the black water tank.
How do I seal this leak?
In the spring when the trailer is warm, I'm thinking of cleaning off the joint with a small wire brush. Then swab the joint with universal plastic pipe cement.
Alaska Geroge is offline   Reply With Quote
Old 10-27-2024, 12:21 PM   #2
jerrybob's Avatar
Trailer: casita
Clean it up a bit and use Flex Seal Liquid.....good to go. Good luck.
jerrybob is offline   Reply With Quote
Old 10-29-2024, 02:25 PM   #3
I had a cracked pipe in the gray water system that I repaired using a syringe and ABS cement over 5 years ago and it has held up well, perhaps it will work here. I used vacuum pressure to pull ABS cement into the cracks.
I cleaned the cracked area with a scotch-brite pad and not sand paper as I didn’t want to close the cracks.
Cover the black tank vent line with tape or plastic so you can hold a vacuum pressure in the drain line.
Have a helper hand-hold a vacuum cleaner hose in the black tank drain and cover most of the space around the hose with a gloved hand when commanded. This creates a vacuum in the drain line and black water tank. You don’t need, or really want, an airtight seal for the vacuum cleaner hose.
Before applying the vacuum pressure and cement, slightly heat the cracked area with a hair dryer to help the ABS cement to be drawn into the cracks
While the helper is applying suction, use a syringe to apply the ABS cement to the cracked area; hopefully some cement will be pulled into the crack. Keep applying cement while your helper stops applying vacuum pressure, this is to keep some of cement from being pulled all the way through the crack.
I used a syringe with a blunt needle like this to squirt the cement in the cracked area while vacuum was applied. I used the largest diameter needle. I bent a long needle to get to cracks I could not reach directly. I applied enough cement to have extra material on the outside of the cracked area, and put down a drop cloth to catch drips.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It was a bit messy, and doesn’t look great, but who looks under a trailer anyway? I don’t think that anything bad would result if you tried and it didn’t work.
I never used flex seal, but a coating of that sounds like a good idea.
Thane is offline   Reply With Quote
Old 10-29-2024, 04:42 PM   #4
Alaska
Word from Casita
A Casita technician phoned me about the leak. he said the black ABS 90 degree elbow is threaded where it fits onto the bottom of the black water tank. He said it was be better to cut the abs drain pipe past the elbow, then unscrew the elbow, clean the threads, then reseal the male threads with teflon tape, before reinstalling the elbow. The remainder of the drain pipe should be removed at the dump valve the the pipe glued back together with a coupling. Hopefully that will fix the problem without gluing everything together, and make future removal or repairs impossible.
How to use all water in hot water tank and cold water tank? (Scamp) Scamperino Plumbing | Systems and Fixtures 25 06-03-2022 06:18 AM
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
Water meter for back flushing black water tank Lockman Problem Solving | Owners Helping Owners 6 04-12-2019 03:25 PM
Black tank leak Lisa M. Plumbing | Systems and Fixtures 10 05-12-2017 04:57 AM
Black/grey water tank leak? frank_a Plumbing | Systems and Fixtures 28 09-02-2014 08:57 PM
