Location of 7-pin junction box on Casita SD 16 - Fiberglass RV
Old 10-21-2021, 03:35 PM   #1
Trailer: Casita SD 16
Maine
I have been experiencing an intermittent outage of my taillight/side lights on our Casita SD 16. I had previously repaired the 7-pin cable with butt connector and shrink sleeves. Apparently, the green connection has failed within the bundle.
I would like to replace the entire cord but I can not locate the junction box on the trailer. Our SD has a front mounted air conditioner located under the closet. I find no access under the trailer or in the closet. I haven't taken the AC out yet but seems I may find it there.
Can someone please tell me where I can find the location of the junction box?
Thanks
macbethdt is offline   Reply With Quote
Old 10-22-2021, 06:02 AM   #2
Casita has never installed a junction box for the incoming 7-Pin cord. There's just a "rats nest" of excess wiring and lot of Scotch-Lock wire connectors bunched up in the front closet where they made all the cord connections to the trailer's wiring. For those unfortunate enough to have the front closet A/C unit, it's all but impossible to get to without removing the A/C unit. Sorry.
Old 10-22-2021, 07:10 AM   #3
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
If you have room, you might want to replace it with one of these: Cable & Junction Box. They are available in different cable lengths, and quality connectors.
Old 10-22-2021, 09:38 AM   #4
Originally Posted by Casita Greg View Post
... For those unfortunate enough to have the front closet A/C unit, it's all but impossible to get to without removing the A/C unit. .
Sounds to me like the thing to do is to remove the A/C, extend the wires using good quality butt splice connectors, run the extended wiring to someplace where you can mount a junction box and always get access to it after the A/C is reinstalled. A box inside is best if everything can reach but a weather proof box on the tongue can work also. That way you can replace the cord easy enough in the future.
casita
Using 7 Post Junction Box brettrae Electrical | Charging, Systems, Solar and Generators 6 11-24-2020 11:39 AM
Junction box for cable LCarlson Problem Solving | Owners Helping Owners 6 06-18-2020 04:52 PM
Trillium 1300 cloaet junction box question Trillium-Pettis Electrical | Charging, Systems, Solar and Generators 2 06-16-2015 09:01 AM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
