Our 2011
Casita SD has the
microwave cabinet over the
refrigerator. I have never used a
microwave in it, I've always used it as a pantry.
One of the screws in the hinges of the door is loose. Ordinarily we'd just tighten it up, but the fact that it's loose in the first place makes me want to tighten it or replace it.
The screws are 3/4" wood screws, which don't seem to be substantial for that much
weight.
I'd liked to upsize the screw to something a little more substantial, but if it's just going through a thin piece of scrap wood (something I've found
Casita used a LOT in places that you can't see) then a longer screw wouldn't be much help.
Problem is the shaft part is hidden under mouse fur (carpeting) in the pantry. I do not know how it is mounted.
Is the screw mounted directly into what I assume (I know, I know) is 3/8's OSB? For that matter, is the floor of the pantry OSB at all?
Or is it inserted into a piece of wood that's flush with the
fiberglass?
I hesitate to pull up the carpet until I know how it's installed. Glued? Just kindasorta Stuck?
Thanks for any advice.
