Outdoor light has bad connection - Fiberglass RV
Old 12-26-2019, 10:08 AM   #1
Trailer: Scamp - Gently Used
Kentucky
I have an outdoor light with a bad connection. What would be the best way to fix a bad crimp on this light socket?
The crimp on the north post on this socket isn't maintaining contact and drops connectivity when I close the light up.
Any help would be appreciated.
thanks,
Rogue
Kris & Scott | 13' Scamp Standard | 2014 Mazda CX-9 Grand Touring
RogueIT is offline   Reply With Quote
Old 12-26-2019, 10:19 AM   #2
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
A new connector…
Old 12-26-2019, 10:21 AM   #3
Kentucky
Originally Posted by Wayne Collins View Post
A new connector…
Does anyone have a part number?
Old 12-26-2019, 10:24 AM   #4
Trailer: Parkliner
Iowa
Any auto parts store should have them. Take the old one with you,
Old 12-26-2019, 10:30 AM   #5
I suggest you take that picture to an electrical parts store (not a discount shop) and try to buy the connector and get yourself a proper electric crimping tool and try that. I am having the same problem with the horn on my car and the cheap (silver) connectors are that! In wiring, cheap ends up costing you time and frustration and is crap.
jokra is offline   Reply With Quote
Old 12-26-2019, 10:33 AM   #6
Trailer: Jayco
Louisiana
thanks,
Rogue
Rogue, I would suggest you cut the bad connector out and strip the wire back about 1/2" on each end then use a wire nut to rejoin the ends after you twist then together. If there is any discolored copper, dark brown, strip it more and discard the burned part before reassembly. That should get you all fixed up. Good Camping ........ Jim
jimknoch is offline   Reply With Quote
Old 12-26-2019, 10:45 AM   #7
steve67's Avatar
Trailer: 79 Boler "Van Gogh"
on Ontario
Had the same problem on my Boler. Found that the grounding was inadequate. I added the short blue wire to make for a better ground.
steve67 is offline   Reply With Quote
Old 12-26-2019, 04:08 PM   #8
Whatever number that bulb is Google ****bulb socket and see if something similar to yours comes up.
Lee
Captleemo is offline   Reply With Quote
Old 12-27-2019, 03:30 PM   #9
Kentucky
Thanks man, we were headed to pep boys anyway
light
Outdoor Light MELTDOWN. Nik Electrical | Charging, Systems, Solar and Generators 12 08-26-2019 10:25 AM
Yellow Outdoor Light glennco Modifications, Alterations and Updates 28 03-11-2015 10:48 PM
Who has "replaced the water heater with a outdoor camp shower unit? ShawnKK Modifications, Alterations and Updates 23 08-23-2013 08:40 PM
Inside switch for outdoor light? Legacy Posts Modifications, Alterations and Updates 2 11-11-2002 09:00 AM
